To the dealer for service!
diablomike63
Post by diablomike63 »
Hey everyone I have a 2010 Dodge Challenger SE I need to take to the dealer for service on my air conditioner, my question is do you think I need to remove my sport tune back to stock, I feel I finally got the ultimate tune on this car, with the throttle boost and shift firmness, I don't want to lose this tune, since I am having no engine work done should I leave the sport tune on it? Thanks!
RE: To the dealer for service!
I wouldn't leave it. You never know when they'll flash the computer. If you decide to leave it, definitely put a cap on the OBD-2 port and make sure they know not to flash the computer.
LeHemi
Post by LeHemi »
You should be able to upload last tune written to your computer, unless I am mistaken. So you can return to stock and then reload the tune after the service trip.
diablomike63
And that would also include the throttle boost setting as well as the shift firmness setting that I had set on the car, or would it just reinstall the 93 Octain tune and I would have to set the other things manually?
diablomike63
Hey administrators, is that true if I go to last tune will it also uplaod my throttle boost setting and my shift firness setting I also had on the tune? Thanks!
once you restore the stock tune, all parameters are reset, so you'd have to redo those changes when you reload the tune.
