Intune frozen at startup screen
overkill
Post by overkill »
As title says. Main menu loads but completely unresponsive.
I've had it connected to my PC for about 2 hours now to ensure it wasn't in the middle of updating etc.
If I open both the DiabloSport or removable disc folders, there's nothing within each folder.
Any suggestions?
JonDiablosport
RE: Intune frozen at startup screen
Post by JonDiablosport »
so you are never presented with an INTUNE drive on your my computer screen.
or it allows you to open the "removable disk folder" and nothing apears,. is that file name appearing only when the intune is plugged into a computer. and finally can you try to plug into another computer to see if the same results persist.
Diablosport Tech support
p: 561-908-0040
F: 561-908-0048
overkill
Post by overkill »
The drive does present itself. A screen comes up with removable disk and the tunes folder, but if I click on the tunes folder there's nothing in there. If I go back, the main folder is now blank.
If I right click on the drive names diablosport and select autoplay or start intune updater, it asks me what program to use to open with.
Meanwhile the Intune itself boots up but the screen freezes at tune/scan/settings, I can't scroll at all.
I haven't tried another computer but I have rebooted this one twice.
overkill
Post by overkill »
TTT
please post the info.xml file from the intune drive.
overkill
Post by overkill »
Cannot read from the source file or disk, it says.
overkill
Post by overkill »
If I try very fast, it almost allows me copy the xml file before it freezes. I can also press one of the tune/scan/settings buttons but it freezes by the time it gets to the next menu.
go ahead and fill out the rma and get it sent in, we'll fix it.
ment0r06
Re: Intune frozen at startup screen
Post by ment0r06 »
I am haveing almost the same issue. I can see it on computer tried to see if it needed an update. didnt help any. It is frozen on main screen. Any help to fix this?
ment0r06
Post by ment0r06 »
ECM_12640535_Backup.grg
(67.64 KiB) Downloaded 494 times
here is info from computer I can get. It wonlt allow me to get the intune.exe to stay up. It looks for updates then errors then closes
info.xml
(3.92 KiB) Downloaded 419 times
TCM_24258799_LastTuneWritten.grg
(52.04 KiB) Downloaded 425 times
TCM_24258799_Backup.grg
(51.09 KiB) Downloaded 395 times
ECM_12640535_LastTuneWritten.grg
(67.97 KiB) Downloaded 373 times
ment0r06
Post by ment0r06 »
12175 is the error code
use the current update agent software to update the device.
http://fusionupdate.com/ignition/powert ... taller.exe
Bpope
Post by Bpope »
I have the same downloaded additional license freeze screen
