2005 cummings stacking questions
white3500
RE: 2005 cummings stacking questions
Post by white3500 »
ok cool thanks for the input. so did you use the rkl extreme puff w/no timing or the rkl extreme stack puff w/no timing. just curious do you think it would make a differance i have an 05 not an 03? sorry for all the questions im new to stacking and just want to do it right. just looking for better bottom end and throttle response.
thanks again any input is appreciated.
05 3500/edge juice w att/ 90 hp nozzles/ arp studs/ bd r700 twins/ fass150/ ind. inj. 33% inj. pump/ banks intercooler + high ram/ napc full race tranny/ snow perf. stage 3 water meth/
ropnjessi
Re: RE: 2005 cummings stacking questions
Post by ropnjessi »
white3500 wrote:ok cool thanks for the input. so did you use the rkl extreme puff w/no timing or the rkl extreme stack puff w/no timing. just curious do you think it would make a differance i have an 05 not an 03? sorry for all the questions im new to stacking and just want to do it right. just looking for better bottom end and throttle response.
Wellllll......if you are new to this and you really want to know....I can tell you my opinion of add-ons. So far I have gone through (2) pistons due to valve seats dropping from excessive heat. I believe the heat was from stacking the pressure box and a TST . Now I only run a tuner other then the hardware installed in the motor. By the looks of your signature it appears as long as you control the EGT's you have a nice setup. You should have plenty of power on the base tunes (I stayed away from the RKL timing tunes as I always got rattle, and excessive smoke even while idling). The Predator does not have any Torque management settings like the Smarty, that is the best way to get bottom end throttle response. Soon EFI will be available to really fine tune your truck.
03'/305 Dually 4 x 4
Smarty SSR,62/65/13ss, CFM+
white3500
RE: Re: RE: 2005 cummings stacking questions
Post by white3500 »
Ya i have been patiently waiting for EFI live i hope it comes out soon. but im not too sure when so im just trying to tune my truck a little better. i just got my twins in and they should spool between 70-75 but the highest ive seen is 60-63 so iwas hoping to get a little more out of them. i tried running just the extreme on the predator and the edge on stock but didnt like it at all. it smoked like crazy and was dead off the start real bad. I thought all the regular tunes had too much timing to stack with the juice, but it seemsto be hard to get any info on timing on any of the tunes. thats why i will try the no timing tunes just wish there was a smaller one than just extreme. The reason i went with predator not smarty was i had one just lying around and didnt want to wast money because i will be getting EFI. do any of the base tunes have no or little timing? which one seemed to work best for you?
thanks again.
ropnjessi
Re: RE: Re: RE: 2005 cummings stacking questions
Post by ropnjessi »
white3500 wrote:Ya i have been patiently waiting for EFI live i hope it comes out soon. but im not too sure when so im just trying to tune my truck a little better. i just got my twins in and they should spool between 70-75 but the highest ive seen is 60-63 so iwas hoping to get a little more out of them. i tried running just the extreme on the predator and the edge on stock but didnt like it at all. it smoked like crazy and was dead off the start real bad. I thought all the regular tunes had too much timing to stack with the juice, but it seemsto be hard to get any info on timing on any of the tunes. thats why i will try the no timing tunes just wish there was a smaller one than just extreme. The reason i went with predator not smarty was i had one just lying around and didnt want to wast money because i will be getting EFI. do any of the base tunes have no or little timing? which one seemed to work best for you?
thanks again.
Have you tried one or the other? Meaning either the Juice by itself or the predator by itself (no stacking). Its been a long time since I ran the predator but the best power was the base tunes stacked with the puc, and I even ran the edge pressure box with it for a time....
white3500
RE: Re: RE: Re: RE: 2005 cummings stacking questions
Post by white3500 »
Ya I have run the juice for a few years, I like it I was just looking for more since I put the twins on. I have tried the predator on extreme with the juice on stock and did'nt care much for it. The edge has way smoother power and better throttle response. The predator was real dead off the start and smoked like crazy, it made good power it was just so unresponsive. I have not stacked the two yet. I am waiting for my 5 inch staight exhaust it goes on on thursday. I would be fine running the predator on the base tunes with my edge, I was just concerned about too much timing(hard to get any info on how much if any timing is added on any these tunes). I will just have to to some playing around and see. When you ran them together did you have the juie, or just the ez.
ropnjessi
Re: RE: Re: RE: Re: RE: 2005 cummings stacking questions
Post by ropnjessi »
white3500 wrote:Ya I have run the juice for a few years, I like it I was just looking for more since I put the twins on. I have tried the predator on extreme with the juice on stock and did'nt care much for it. The edge has way smoother power and better throttle response. The predator was real dead off the start and smoked like crazy, it made good power it was just so unresponsive. I have not stacked the two yet. I am waiting for my 5 inch staight exhaust it goes on on thursday. I would be fine running the predator on the base tunes with my edge, I was just concerned about too much timing(hard to get any info on how much if any timing is added on any these tunes). I will just have to to some playing around and see. When you ran them together did you have the juie, or just the ez.
With those mods you should be 650-700hp or so. Stupid question maybe, but I don't see what you are using for air filter in your signature (high ram?). I only ran the EZ.
white3500
RE: Re: RE: Re: RE: Re: RE: 2005 cummings stacking questions
Post by white3500 »
Ya thats what i was thinking i should be around for power, but it just doesnt seem like the truck has it. The high ram is banks intake horn. The air filter is what came with the bdr700 twins, I dont really like the intake the filter seems small and the piping does also. Before the twins i had an afe and it was twice the size in every way. I have been thinking of a battery relocate so i can make my own intake, but i just havent figured out how yet.
Ok i think the juice does timing and the ez does not it just does pressure. So i am thinking that the only tune i can safely run is the rkl stack extreme with no timing. I will try it and see. If it does not work i think i will scrap the predator and get a pressure box, just didnt want to do that cause then i wouldnt have a accurate fuel pressure reading.
Thanks again for your input.
ropnjessi
Post by ropnjessi »
white3500 wrote:Ya thats what i was thinking i should be around for power, but it just doesnt seem like the truck has it. The high ram is banks intake horn. The air filter is what came with the bdr700 twins, I dont really like the intake the filter seems small and the piping does also. Before the twins i had an afe and it was twice the size in every way. I have been thinking of a battery relocate so i can make my own intake, but i just havent figured out how yet.
Have you looked at these yet? The BD Turbine Diverter Valve?
white3500
Post by white3500 »
I just looked at them. Maybe that is the way to go. Id be concerned with higher temps with it. I have decided after all this i dont think stacking the predator is the way to go, maybe a epp would be better (that means gauges as well). I got my 5 inch exhaust on and it did not drop my egt like i thought. So now i have to spend my money trying to drop the egt before i contine looking for more power. As far as i can tell i have done all that i can besides increasing the water meth or even changing to a better intercooler. From what ive been told by guys running race trucks the banks system is not as good compared to afe. They said that they saw 200 deg drop when they switched. I can hit 1650 plus quickly. Would a bigger air intake help drop egt? Any other suggestions.
thanks again.
ropnjessi
Post by ropnjessi »
white3500 wrote:I just looked at them. Maybe that is the way to go. Id be concerned with higher temps with it. I have decided after all this i dont think stacking the predator is the way to go, maybe a epp would be better (that means gauges as well). I got my 5 inch exhaust on and it did not drop my egt like i thought. So now i have to spend my money trying to drop the egt before i contine looking for more power. As far as i can tell i have done all that i can besides increasing the water meth or even changing to a better intercooler. From what ive been told by guys running race trucks the banks system is not as good compared to afe. They said that they saw 200 deg drop when they switched. I can hit 1650 plus quickly. Would a bigger air intake help drop egt? Any other suggestions.
thanks again.
Seems odd the EGT's are staying so high, have you adjusted your wastegate?
white3500
Post by white3500 »
Ya it's closed all the way, and I put a boost T in and it's closed all the way.
