traction control/stabilitrac override?
bigboyblue
Post by bigboyblue »
2010 silverado 6.2L
Im trying to find away to turn off all traction control but still cant.
Ive tried pressing the traction control button, but it still kicks in.
Ive tried holding the traction control button, even with stabilitrac disabled, it still kicks in.
Is the intune capable off deleting traction control and ABS completely, or do i need to run a bypass switch from the fuse to kill it.
RE: traction control/stabilitrac override?
ABS, no, TC can be disabled fully in a custom tune.
bigboyblue
ok, so if i want to kill abs for off-road use, i gotta pull the fuse right?
I'd imagine thats the best option.
mblatz
Post by mblatz »
I-1000 intune, latest update
2008 dodge ram 1500, 4.7l motor
when i initially disable the traction control using the programmer (there is no actual switch) on my truck, if I do not key-off, just start the truck and drive, it seems to use [D] in third gear only and [2] and [1] in second gear even if i mash the pedal to the floor. any ideas? after key-off it works normally (with the ABS and BRAKE light on, of course)
mblatz
Post by mblatz »
Bump for mod
Its throwing a code after the tune. You always need to key off and restart after a tune to cycle the computers power and clear it out.
can you post the info.xml file please/
this issue should be resolved with the latest 1r02a release.
