U7137 Wrangler Shift Adjustment
RE: Re: U7137
Is this a beta for the U7137 that will work with the Predator?
Thanks.
Thanks.
midevil214
RE: Re: U7137
Looks like you posted the Trinity update. Do you have the Predator update to the U7137 that this thread is discussing? Will this have updated CAL ID support for AH CALs?
Re: RE: Re: U7137
oopsmidevil214 wrote:Looks like you posted the Trinity update. Do you have the Predator update to the U7137 that this thread is discussing? Will this have updated CAL ID support for AH CALs?
midevil214
RE: Re: RE: Re: U7137
Thanks....Will give it a shot and report back.
Update: Installed 9t14a_181 crom and sadly no 3-4 shift control as promised. OSS numbers are still labled as rpm with same adjustability problems as noted in prior posts.
Is there anything in this revision that pertains to a 2010 Hemi Ram?
midevil214
midevil214
We found the issue, looks like the 2010 params got missed, everyone else should have the 3-4 stuff and fixed oss values.
We'll get a new update done this week to fix it
Here you go guys, enjoy....
Same here...'06 5.7L Jeep and no 3-4 shift when modifying custom tune via Predator...is it fixed in the "b" version, or was it just for the '10s?midevil214 wrote:Installed 9t14a_181 crom and sadly no 3-4 shift control as promised. OSS numbers are still labled as rpm with same adjustability problems as noted in prior posts.mikel wrote:yes, 3-4 will be added for wrangler.
fixed.amw wrote:By the way...just tried to download the new beta crom and the link is bad.
