RAM owners, I need some input...
Ok, so I have a 2010 RAM 1500 Quad Cab 4x4 Big Horn. I have an issue with my intune and noise. I have tried all the tunes and it never fails, when I punch the gas and it shifts it always makes a diesel like rattle noise, very loud. Not sure if it is the valves going crazy, or what. I have never gotten any warning lights, but it sounds loud and it is very annoying. I do not want to damage my RAM, but I do love the added power and MPG it gives. If anyone that owns a RAM has the same kind of noise, please let me know. I would love to be able to adjust a parameter in order to stop this noise. When I run is stock, no tune, it does not do this. It only does this when I tune it with the intune. I would appreciate good advice on this matter. I know it is not the gas I use, nor is it because of the RAM itself. It only makes this noise after I tune it.
RE: RAM owners, I need some input...
I have no fellow RAM owners that have this issue?
BlackZ71Silverado
Try doing a datalog at regular speed while cruising. Reading the log may tell you if there is a problem and when it is exactly happening.
What tune are you running and what fuel is in your truck?
2010 Silverado Ext.Cab 5.3L
MBRP exhaust
AirAid MIT AEM filter
Black bear Performance Tuned
2008 Silverado Ext. Cab 6.0L Vortec Max
GMPP exhaust
GMPP CAI
Black Bear Performance Tuned
MBRP exhaust
GMPP exhaust
GMPP CAI
That is the problem, it does not matter what tune I use. I put the right octane in for the tune. It sounds like a diesel when I jump on it and it shifts after i get on it. It only does it when I am using the intune. It runs with no noise when in OEM tune a.k.a no tune.
