Latest Intune release here.
dieselman1985
Re: Latest Intune release here.
hey guys i am just now getting around to trying to update my intune, i know im behind, but i was wondering where i should go to get the current update. i have the 1r01h file and i think that this is the latest calibration file but i wanted to be sure. Also, when i try to do a log to analyze my truck, it says that it doesnt support that. 2007 dodge ram 1500 5.7 hemi 2wd
dieselman1985
hey guys, i already have the 1r01h application files, but it seems that the other files arent current. i tried to find the update files but didnt have any luck. so i have 2 questions, first is when i plug my intune to my laptop it boots up like it is connected to my truck and doesnt auto update. so does that mean its current and needs no update and if not where do i get the uploader program so that it will update. 2nd is how do you log the info on your vehicle?? everytime i do it will not let me look at the data.
im not sure whats going on when i try to tune it tells me pcm calibration for 2c3ka63h76h356710 might need an update check for calibration upgrade when i try to upgrade on pc it tells me i need to contact tech support what i do
- info.xml
- (555 Bytes) Downloaded 667 times
04cummins59
nothing is making my intune work. ive sent it back to you and just got it back today and now it says there is a problem and uplug and try again. nothing seems to help it
Is there any way to receive a PM or e-mail subscription to when updates are released for the InTune?
how do i find out what my intune level is at (1r01i-1r02c)??...thanks..chris.mikel wrote:1r01i is an important update that corrects a possible bug, we strongly recommend everyone update to this asap to ensure stability of your tool.
If you are on 1r01i or higher, you may go straight to 1r02c
fluidfalcon
You connect the inTune via USB cable to the PC/laptop. Once it completes loading (status bar screen) and you can see options to click--->status/tool info--->firmware version. It will list all the files updated on the inTune.hoorsec wrote:how do i find out what my intune level is at (1r01i-1r02c)??...thanks..chris.
I received an email this topic thread is updated. But no new posts seen.
When I connected the inTune to the PC and ran "inTune" software.....it updated to 1r01j.
So the posts above about 1r01i seem to be out of date? Is that the "cdrom" or "updater" software on the inTune device? (Accessed like a thumb drive on the PC)
The bold below are noted "OK" after updating, menu displayed on the inTune handheld.
I assume "OK" means new changes to the firmware.
Application: 1r02d
DCX Tune DB: 1r01b
DCX PID DB: 1r01a
Ford Tune DB: 1r01f
Ford PID DB: 1r01a
**GM Tune DB: 1r01l
**GM PID DB: 1r01a
**VIN DB: 1r01a
DTC DB: 1r01a
Info DB: 1r01b
jsmith78910
i cant download thismikel wrote:1r01i is an important update that corrects a possible bug, we strongly recommend everyone update to this asap to ensure stability of your tool.
Just wondering if there were any new updates in the works, or anything like that. Thanks.
paul swann
does not recognize my 2005 jeep tj
I see that the latest version is 1r02d. My inTune is on 1r01k and says it's on the latest software load.
How do I get the newest version loaded?
Hi
I updated my Intune but it wasn't enough.
Intune said to me that I need to update any other whatelse (I can't remember exactly).
Well, I was desperated so I've downloaded last bunch of files you've attached and I've copied them into the intune folder.
Is it right or do I need to remove those files?
Thank you
Thank you
Is there a certain tune for the intune for an 2004, Hummer h2
Help! My first tuner. I1000. Version 1r02c. Born 08/15/2012 02:07:04 PM. I used the quick start guide and loaded the mpg booster. (noticeable gain). The Quick start says run auto update software for the first time. So I've been trying. not working. I found that is the procedure for pc owners. More help needed. This is also my first Mac I'm not familiar with how to use drag and drop. It's difficult to ask, but would you walk me through out of the box procedures to get updates etc...??? Thanks
Either this thing doesn't work with my 2005 Ram 1500 or it isn't user friendly for me. After clicking on write vehicle, it shows "PCM Calibration for [VIN] might need an update. Check for a Calibration Update?". When I connect to the PC everything is up to date. Then it goes directly into the Tune TCM menu. Not sure where to go from here.
