Update for Ford F150 09-10
I have updated my Intune with the current software available from the autoupdater but when plugging in to my 2010 F150 5.4L it says vehicle not supported. What am I missing?
Re: Update for Ford F150 09-10
can you tell me the calibration ID that it gives you?
(settings/tool info/vehicle info)
Calid: 12636005, 12637461, 12637628, 12625892, 12620683, 12636563, 12620814, 12620776.
those are GM calids, are you plugged into a GM vehicle?
No, but I had used it as a demo on a GM Vehicle previously. This was before attempting to load it on to the 2010 Ford F150.
when you can, please plug into the F150 and select settings/tool info/vehicle info and tell me the calid.
its a customers vehicle, its not here. Any other options?
can you ask him for the 4 digit box code on the PCM?
Coincedence... he just stopped by. cal id #: RXGE6GB
this update will add support fro that truckumbrae wrote:Coincedence... he just stopped by. cal id #: RXGE6GB
- FORD_TUNES-1t01fc.ITF
- (9.33 MiB) Downloaded 342 times
Do I just copy and paste this file in my Intune folder and it works?
yes sir, drag/drop or copy/past the file to the intune drive, let the tool reboot, and it will work
thassanien
same problem
i tried your update
the problem is the same
my calic is RXFKCB5
VIN 1FTPW14V49FA22957
i tried your update
my calic is RXFKCB5
I think you emailed us about this, no?thassanien wrote:same problem
i tried your update
my calic is RXFKCB5
We're checking it out...
thassanien
after recieving update from support people
when i upload the tune or modify one of the stock parameter engine wont start
