Not very happy with the Trinty
Re: Not very happy with the Trinty
I am seeing the following after updating the latest file posted in this thread.
From the Diablosport tool information tab(downloader connected to trinity)
CROM version = 'dcx_gas-1r09c 11/09/2012 05:21:27 PM boot4'.
Is this correct??
I thought it was supposed to be dcx_gas-1t09c ??
Is this correct??
Mine shows the same thing too- I think it was just a typo in the file name since the r & t are next to each other on the keyboard.txsport wrote:I am seeing the following after updating the latest file posted in this thread.
Is this correct??
This is the correct update.....
- trinity_dcx_gas-1r09c_update.crom
- (2.78 MiB) Downloaded 270 times
12 Charger SRT8: LMI Intake, SLP LM exhaust........waiting on CMR, then il buy a Trinity
Bullet, if you check earlier in this post, they posted one for the issue we were having with shift points at part throttle shift. It was a T version that came after the R version.
It may be that DS just gave us the 93 Oct tune update rather than the whole update. I just wanted to verify with DS that was the case.
Oh ok.....well hope DS can clear it uptxsport wrote:Bullet, if you check earlier in this post, they posted one for the issue we were having with shift points at part throttle shift. It was a T version that came after the R version.
the fix for the 11 ram shifting issues is 1t09ci.
mikel,
Is there a way to look at the Trinity and tell if it is installed??
mikel wrote:the fix for the 11 ram shifting issues is 1t09ci.
Go to Options, and then Show Information. Version is the 3rd line.
2011Longhorn
Part throttle shifts are working great, but I don't think the WOT shifts are right. I have them set at 5850 rpms for 1-2 & 2-3 shifts, but the 1-2 shifts at 5600 and the 2-3 shifts at 5760. I'll have to check again in the morning since it was raining and there was to much traffic tonight.
2011Longhorn
I checked again this morning and part throttle shifts are working great but the WOT shifts are not. I have them set at 5850 rpms and the 1-2 shifts at 5600 and the 2-3 shifts at 5760. I also can't change the tire size. I'm trying to change it to 305/45/22 and it will not except the change.
ok, can you post your calid for me again please?2011Longhorn wrote:I checked again this morning and part throttle shifts are working great but the WOT shifts are not. I have them set at 5850 rpms and the 1-2 shifts at 5600 and the 2-3 shifts at 5760. I also can't change the tire size. I'm trying to change it to 305/45/22 and it will not except the change.
2011Longhorn
68059108AHmikel wrote:ok, can you post your calid for me again please?2011Longhorn wrote:I checked again this morning and part throttle shifts are working great but the WOT shifts are not. I have them set at 5850 rpms and the 1-2 shifts at 5600 and the 2-3 shifts at 5760. I also can't change the tire size. I'm trying to change it to 305/45/22 and it will not except the change.
we're checking out the shift stuff.
1r09c is back up, and everything else is working properly for anyone with an issue.
2011Longhorn
