2012 Challenger R/T with K&N CAI, 85MM throttle body
Re: 2012 Challenger R/T with K&N CAI, 85MM throttle body
what rpm does the kr start at?
should only need to add more fuel inthe middle rpm range, try that.
Peter_beresky
It's looking like right around 2800 rpms
Peter_beresky
Ok I figured it out. I had to add a lot of fuel to get it to not knk. I also put better fuel in the car. Here is what I had to adjust too:
WOT. Knk st. Knk lt
1000-3800. :13. 0. 0
4000-4800. :11.5. 0. 0
5000-7000. :9. 0. 0
WOT. Knk st. Knk lt
5000-7000. :9. 0. 0
looks like the TB may have leaned it out a bit, along with the CAI.
Peter_beresky
eric.hauptman
what is a safe knk st and lt retard? I am getting up to 6 on knk st, but when i get knk lt it's like between 1.00 and 1.50
2011 Challenger R/T 5.7
K&N CAI
Magnaflow exhaust
K&N CAI
Magnaflow exhaust
add some fuel...
eric.hauptman
I just found the misfire cnt parameter and it reads out at 4-5 right after i plug it in and the engine is already running and after about 10 minutes of driving its as low as 6 and as high as 11! Any ideas on how to fix this?
misfires are not caused by a tune....put it back to stock, I bet they are still there
eric.hauptman
I'll try that is there any tuning i can do to get rid of it?
Misfires have nothing to do with tuning. Its either a plug or coil issue.
eric.hauptman
I noticed that the misfire count is a lot higher when it's cold it was up at 16! When it go was warmed up it was at 4
makes sense...
eric.hauptman
I was wondering if there was any monitor guages that could be set up for data logging to determine where the misfire is coming from?
