Cannot register Intune
When I get to the registration screen I get "SMTP error. Bad login or password (406)"
I have tried turning off my firewall and all antivirus/intrusion prevention etc.
Tried while running as administrator.
Anything else I should try?
'11 Sierra Denali
'69 Firebird
'69 Firebird
gnarlyhawk
Re: Cannot register Intune
Same error for me. Tried a Windows 8 & 7 machine.
SMTP error. Bad login or password 406
Bad configs on your side it seems. This is a bummer, early present from my wife so I can play with the vette during the holiday vacation.
make sure there are no special characters inthe submissions lines, or caps lock, etc...
I am having this same issue trying to register.
can you guys provide the email addresses you are using to register?
I have try 2 different email address and 2 different email programs
[email protected] and [email protected]
ok, we'll sort it out.
if anyone needs to register now n order to update, post the info.xml file from the intune drive here please.
Here is mine.
- info.xml
- (463 Bytes) Downloaded 1382 times
drag/drop this file to the intune drive, let the tool import it, and it will be registered.Tight_wad wrote:Here is mine.
- registration.itf
- (858 Bytes) Downloaded 1493 times
Thank you very much. Will I need to do something on registering it under my name at a later date?
no need....
FYI, this is fixed now
hey mike, i also am having the same issue today trying to register my intune, i went to work to use the pc to register it and now at home using my mac to try to download the tunes and such (mac only in my house) so i can flash my srt8. is there anything you can do for me to register my device on my mac @ home or should i wait until tomarrow to return work on the my pc to register it since you stated that it was fixed?? thanks for your time!
wait til you can connect it to a Windows PC...
or, run Windows on your Mac...
graysonpahl
Hey , I have problem as well to register my device here is my xlm file
my email [email protected]
- info.xml
- (510 Bytes) Downloaded 1179 times
