2010 ratpor 6.2l cannot read original backup
lightning
Re: 2010 ratpor 6.2l cannot read original backup
Post by lightning »
Yes but I do not have one to test the raptor tune. :wink: Somehow you guys came up with one. Thanx
lightning
Post by lightning »
Worked, tune installed, need to work on the shifting quality. I will dyno and tinker sometime soon, Thanx brent
sohfast94
Post by sohfast94 »
Post your last tuen written. It'll be slow around here this week so I'll ahve time to mess with it....
Insert Clever comment here...
lightning
Post by lightning »
Truck shifts very fast through gears, also sounds as if torque converter stays unlocked entire renge of shifting. I like trans to shift fast and firm. Also I see tune has off road mode transmission configure in it, can we adjust how it shifts in off road mode? Or make rear diff stay locked in all speeds in 4x4? I will send in a minute, the last tune did not save in trinity.
lightning
Post by lightning »
Trinity says failure retrieving tune, reported failure was ecm unable to export tune? I have tried it twice. Any Ideas?? I can give you stock backup.
2010RaptorRoseStockTune.frg
Stock Tune as reported by Trinity.
(987.93 KiB) Downloaded 295 times
lightning
Post by lightning »
Tried with 91 tune also, truck will not report ecm tune.
sohfast94
Post by sohfast94 »
see if you can load this.
hit send tune to tool and select this tune, then it will ask you for a second file that will be your original backup.
2010raptor_R1.frg
(740.12 KiB) Downloaded 314 times
lightning
Post by lightning »
Is this a different tune? Snowed here today so driving an feeling trans shift might be hard, I will try.
sohfast94
Post by sohfast94 »
Yes it is.
Return to “Trinity Ford Gas”
