Few issues with E version Tune.. 2012 SRT Charger
rbasco
Re: Few issues with E version Tune.. 2012 SRT Charger
Post by rbasco »
I am using the F version and all seems pretty good. The E version seemed good also, but, on both tunes, it keeps telling me it can't update my tire sizes. Any ideas why?
Bullish
Post by Bullish »
mikesrt8superbee wrote:
Bullish wrote:I will be on vacation till Jan 2nd..
So I will try it then.. However with the help of DS I was able to adjust my shift pts via quick adjust and was advise I could still adjust my throttle boost. I did both with the E and MAN O MAN.. Wow.. So I look forward to uploading the F so I can make my adjustments via the main menu instead of the quick menu and adjust other things as well.
what exactly is the shift points and why would you want to change them? is it just a raised redline?
Per DS and others it makes the car go faster...
and judging by my car's performance... It seems be running better and faster.
I plan to do some 0-60 runs to compare it to my last 0-60 run..
My Stock to Rock Pictures
http://www.jamcarclub.com/showthread.php?t=18
Bradd_D
Post by Bradd_D »
What did you change your shift points to?
Bullish
Post by Bullish »
All I did was click Raise...
UPDATE...
Well I waited for the F tune to come out which was suppose to fix some minor issues..
I download it today.. And my minor issues were not resolved.. I still have to go to Quick Adjust to raise my shift pts.. I guess bottom line it doesn't matter how you get there as long as you get there correct?? But still I wonder why I can not adjust my shift pts via the regular adjust menu.. Makes me wonder where else I am falling short on with my Trinity when it comes to what it can do.. Anyway... I plan to be in Tampa FL on business at the end of the mth where I get my STOCK DYNO Pull done @ 417 HP... I plan to pass by there to see what kind of pull I can get with the tune..
however I am not holding my breath...
Because my 0-60 Stock time was 4.86 and my Tune 0-60 time was 4.82...
Now I am no speed expert but that doesn't sound like much of improvement to me..
Sorry but for now The Trinity will just be a displayed object in my car for shows until a custom Tune becomes available.
mikesrt8superbee
Post by mikesrt8superbee »
so does the shift point raise the redline?
