Latest Intune release here.
- Vas@Diablosport
Re: Latest Intune release here.
Here are all of the latest files as of 1/2/13
- VIN-1r01b.ITF
- (4.98 KiB) Downloaded 1074 times
- InTune-1r03a.itf
- (1.52 MiB) Downloaded 1076 times
- GM_TUNES-1r01m.ITF
- (4.67 MiB) Downloaded 1107 times
- FORD_TUNES-1r01g.ITF
- (9.21 MiB) Downloaded 1087 times
- DCX_TUNES-1r01b.ITF
- (8.41 MiB) Downloaded 1118 times
No, i don't work here.
fluidfalcon
[email protected] for the heads-up.....pulled the updates tonight!
Is there anywhere on the forums that list the changes/deltas with the latest GM update file? Do you make changes to most of the existing tunes or just add new vehicles that weren't in the database before? (I have a '09 Pontiac G8 GT 6.0).
generally they are not updates to existing tunes.. they are to fix any minor bug issues that may have been discovered, and to add support for additional vehicle ecm's / tcm's....
Shane01638
I would like to know the updates/changes as well. Maybe a new fix/feature or something that would be nice to know about. Like when you can view balance rates for an LLY directly on the intune.fluidfalcon wrote: Is there anywhere on the forums that list the changes/deltas with the latest GM update file? Do you make changes to most of the existing tunes or just add new vehicles that weren't in the database before? (I have a '09 Pontiac G8 GT 6.0).
Also a mailing list you can sign up for based on your specific device that let's you know when there is an update would be nice too.
2005 Chevrolet Silverado 3500 CC LB Dually LLY Duramax 6.6L
inTune Programmer
Straight Pipe, LBZ intake, Kodiak MP,PCV reroute, EGR blocker, finger stick, boost stick
inTune Programmer
My iTune just came in the mail today, when I use the auto updater will it give me these latest files?
I have a 2013 Camaro SS/L99
fluidfalcon
øøø Removed øøø Process posted by MonteSS is correct. øøø
when you first get it - the first thing you will need to do is connect it to your Windows PC and do the registration via the auto-updater app that starts up to register it.. if you don't register it, you are only allowed to do two or three updates to it - and there are a lot more than that that you will need to let it do, hehe...
after you do the registration, let it do its updates... there are a lot of them, so it may take a while (30 min?)...
and when it seems like after its finally done and just sitting at the main screen, then unplug it from your pc, wait a few seconds... then plug it back in again.. and it will probably do some more updates.... then, maybe do this again just to make sure...
after all the updating is done... then you can connect it to your vehicle and select a tune to install...
12blkhdfxdb
Updated my tuner Thursday night. Installed the tune last night at 8. Install FAILED, backup FAILED, truck has a new RCS code. Tuner wont come out of its recovery mode, I've tried every update, and of course it's Saturday so no one is in the office and I have no truck and no way to fix it. Jon, Mike, Vas, I hope you check you email! I'm so screwed and so pissed. Been on this since 8pm last night and its 2pm now, 5 hours of sleep!!
12blkhdfxdb
Waiting, downloading,
12blkhdfxdb
12blkhdfxdb
Left the tuner hooked to my PC all night (6-7 hours). Now I'm showing all (ok)'s again. Ran the updater several times and it stayed showing all (ok)'s so I checked all the files and got brave and hooked it back up to my truck. It is running through the reprograming way to fast. Still in recovery mode. Same stuff different day.... I'm either locked out or my back up is corrupt..
12blkhdfxdb
GROUP UPDATE!!!
OH PLEASE LET THIS WORK!!
12blkhdfxdb
WHAT is it preparing, again? What is it writing, again? Keep getting "in recovery mode. Continue?" and den, F A I L
