just bought u7164 for my 08' f450
gliddd
Post by gliddd »
ive read that this tuner clogs up ur dpf, is this true? im basically trying to figure out what to look for problem wise. i should recieve it around next wednesday and then ill be installing it. has anyone used this on there 6.4 and if so how is it?
Re: just bought u7164 for my 08' f450
older revs had an issue with the extreme tune, it has been corrected.
ACDOCTOR
Post by ACDOCTOR »
HEY THERE FELLAS. I HAVE A PREDATOR U7164 FOR MY 08 F-250, MY TRUCK WAS FLASHED. NEED TO KNOW IF IT WILL WORK WITH MY NEW FLASH.
THE CAL IDS ARE #1 8U7A-14C204-FF
#2 8C3A-14C337-CA
I WILL UPDATE TO THE NEW CROM R16. ALSO HAS THIS TOOL BEEN FIXED TO FIX THE TIRE REV ON 37 IN TIRES.
THANKS
if it was just flashed, no, it will not work yet...
ACDOCTOR
Post by ACDOCTOR »
IT WAS DONE ABOUT 4 OR 5 MONTHS AGO.
ACDOCTOR wrote:IT WAS DONE ABOUT 4 OR 5 MONTHS AGO.
new update here, should be good to go.
u7164-9t17a.crom
(4 MiB) Downloaded 440 times
