ERORR CODES ... HELP !!
OMANOOOO-9
Post by OMANOOOO-9 »
i got this codes
* P0700 Transmission
Control system ( MIL Request )
* P0730 incorrect Gear ( Ratio )
* TCM ( trouble codes below )
* PCM ( trouble codes below )
the gear shifting so early and stuck in in 5th gear
and some times the gear come free ...
D or R NOT WORKING
until reduced my speed under 49 K/M or Switch off the car
Chrysler 300C 5.7 Hemi 2006
Re: ERORR CODES ... HELP !!
does the vehicle have aftermarket gears installed?
OMANOOOO-9
what is that mean ? :?: :?: :?:
IRONMAN77
Post by IRONMAN77 »
Good day.
I have a similar problem, when you load the tune of 91 I threw the code referring U0101 communication failure of the transmission's computer, I appeared as the traction control off without doing so, I had to go back to stock settings and erases codes for a correction
OMANOOOO-9
i already restore the original backup and erases the codes ... :roll:
was the rear gear ratio (axle ratio) changed?
OMANOOOO-9
mikel wrote:was the rear gear ratio (axle ratio) changed?
i dunno but am trying to change axle ratio by T-1000
but i got failed to update axle ratio !
OMANOOOO-9
:normal:
why are you trying to change it in the trinity?
if it has not been changed inthe rear end, it should not be touched in the trinity..
OMANOOOO-9
for the record
the problem was from TCM
i changed it n back 2 the streets again :)
onebadcharger
Post by onebadcharger »
So if I have not changed the actual gears in the rear diff then I should not Use the axle ratio portion on my intune??
Exactly. You can't change something mechanical electronically. You need to actually change the gears. The selection in the Trinity is to correct the speedo and shifts after a mechanical gear change.
