New 6.4 tunes, added TCM support for 6.0s!
This update adds support for all the new 6.4 calibrations, with all new tunes, in addition to adding Trans tuning support for 6.0 customers.
Enjoy!
Enjoy!
- trinity_ford_can_diesel-1r09a_update.crom
- (3.86 MiB) Downloaded 1086 times
- Ill_Born_SS
Re: New 6.4 tunes, added TCM support for 6.0s!
does this mean there is CMR support for these puppies!
" Just Friggin Wicked"
Now with TCM support...
Just CMR for 6.0, not 6.4 yet.
i put in the new update but stall says does not support CAL ID 8U7A-14C204-CK can you help. thanks I have the Trinity and it is for my 2008 F350 Ford 6.4L PS.
options/show information, what is the version shown there?
my version is v.1r09a
is this a manual trans truck?
Could you go options -> troubleshooting -> show calid
Make sure you post both of them please.
Insert Clever comment here...
the truck is automatic. Unit 1 is the only one that comes up (not supported) . Cal.ID Unit 1: 8U7A-14C204-CK Unit 2: 7U7A-14C337-AB
Found it. Added it. I'll post crom here when spun. Shouldn't be long.
Thank you very much.
Take your trinity and connect to computer and open dsdownloader. Then once it connects hit update tool and select the file I posted. It'll load reselect vehicle again and then it'll support your calid.
- trinity_ford_can_diesel-1t09ba_update.crom
- (3.89 MiB) Downloaded 994 times
thanks. i will let you know if it works.
only other question is it says to be used with exhaust system. can this be used with factory or an add on after the dpf. or what do you rerecommend. thanks.
any exhaust mods will work as long as the dpf is left in place.
