U7194 TCM Update
GM doesn't care about tuners at all. Heck, my dealership sells tuners and have no warranty concerns about you bringing your vehicle in with a tune it it.69Zeleven wrote:Still waiting on the fix as well. Gotta tell you, I'll going to be scared to try it on my 07 Avalanche. GM is probably getting wise with all the PCMs getting changed under warranty.
Obviously it's a different story if you break your engine, but thats a feat on it's own. A tune like this won't do it unless you ignore common sense and go crazy with your settings or rag on your drivetrain.
There is a risk of bricking the PCM no matter what you do or which tuner you use (Edge destroyed the PCM in my dad's 2500 Duramax due to a problem with the second battery), and you will have to pay to have that replaced, but no one said that modifying expensive vehicles was cheap.
sweet man!! very glad to hear it!!
no, part throttle / normal cruising AFR will always be 14.75, as the ECM controls that - that's what the fuel trims are for...
you want to get your fuel trims dialed in before you touch any WOT/PE fueling....
