Intune failure
916timmy
Intune failure
Post by 916timmy »
I have an InTune that I want to update for the first time. I read through some of the forums about what to do and here is what I got.
Hooked it up, had to try to run as an administrator to open the program....the window opens for a split second and closes then the intune says preparing until I unplug it. Help????
Re: Intune failure
the first thing you will need to do is connect it to your Windows PC and do the registration to register it... the registration is done via the auto-updater program that runs from the intune itself... if you don't register it, you are only allowed to do two updates to it - and there are a lot more than that that you will need to let it do, hehe... if during the registration, there's not an option for your exact vehicle info, it doesn't matter, just select any make/model vehicle, it makes no difference for this email registration... the important part is that you just get it registered.
after you do the registration, let it do its updates... there are a lot of them, so it may take a while (could take 30-45 min? maybe more?)...
and when it seems like after its finally done and just sitting at the main screen, then unplug it from your pc, wait a few seconds... then plug it back in again.. and it will probably do some more updates....
after all the updating is done... then you can connect it to your vehicle and select a tune to install...
916timmy
Re: Intune failure
Post by 916timmy »
I plugged my intune in today, went to run intune.exe
Said please connect an intune first, screen on the intune said preparing.....
Program won't open
Re: Intune failure
that means the tool is updating, all good.
when it gets back to the main menu, its done.
