ABS and Servic Brake System light
randyc
Re: ABS and Servic Brake System light
Post by randyc »
I know what you are sayin', but sure would like to get what I already paid for sorted out before I pay more for a custom tune.
randyc wrote:it went farther and I thought today was the day, but at about 15 minutes they came back. I did hook up the GPS and speedo was within 1 mph (or less).......................left everything alone just like you said
post a copy of the last tune written please....and the backup.
randyc
Post by randyc »
will do,
randyc
Post by randyc »
Here you go
TCM_24240464_LastTuneWritten.grg
(12.64 KiB) Downloaded 228 times
randyc
Post by randyc »
Mike, I did not notice both of these files do not seem to be updated since the you had me apply the fix.
ECM_12616011_LastTuneWritten.grg
(51.16 KiB) Downloaded 236 times
randyc
Post by randyc »
were these incorrect nd of no use?
randyc
Post by randyc »
randyc
Post by randyc »
bump
randyc
Post by randyc »
Mike,
I re-loaded copies of my backup files 2 weeks ago as you asked................................any progress????
the LTW showed some changes that seem to have been applied by the parameters.
load this custom tune, and when the tool asks if you want to reset params, choose yes, then dont make any changes.
ecm_12616011_new_fix.grg
(47.44 KiB) Downloaded 181 times
randyc
Post by randyc »
I will give it a shot and report back with what happens.
Thanks again!
randyc
Post by randyc »
failed again! Did as you said, loaded, said yes, did not adjust anything......
Should I re-try just doing the ECM? (leave the tranny on stock)?
Mike, I know you are trying and I will do whatever I can to help........................one question, if we never get this sorted out, will I have recourse?
I'll have a new update for the tool to correct this soon, lets just hold out for that :)
randyc
Post by randyc »
will do......................just lmk when, thanks
outdoorsman
Post by outdoorsman »
I would like to know if this has been resolved as I am having the same issue with my 07 new body style silverado with an intune and larger tires.
I found this on another forum, perhaps it may help.
I loaded a superchips tune with the adjusted tire size and gear ratio on my truck and read it with hptuners. I copied my current tune to the superchips file but left their speedo correction alone. The values under speedo are all the same except the general vss pulses per mile. When Superchips does the speedo correction I get a ppm value of 128458 and I also get NO ABS light or parking brake light. With Hptuners, my ppm value was 103585 and I was getting the abs and parking brake light on everytime I drove the car. Anyhow, I found this quite interesting. I have had the larger value in for ppm and I have yet to hear the dreaded chime.
