Latest Intune release here.
Re: Latest Intune release here.
simply plug it into a PC and let the updater run, and it will auto update.
Intune for 2008 Suburban
Can the intune reprogram the ECM with the latest software calibration for 2008 Suburban? I keep getting a engine reduced power indication due to the throttle position sensors being out of calibration.
Having trouble downloading the DS downloader for my Intune. Never had issues when I had my predator. I need to do this so I can email my stock tune and get a cmr tune.
you don't need dsdownloader for anything for the intune...
everything is copy and paste with the intune when you connect it to your PC... the intune shows up as a usb drive in windows explorer... there's a TUNES folder in it, and a LOGS folder...
when you record and save a data log, it will be in the LOGS folder... the tune files will be in the TUNES folder...
copy the files from those folders and paste them to your harddrive... then you can attach them to an email....
i have a 2008 f250 6.4L diesel and wanting a tune for it how do i get it or do yall have a tune
Sinnebuleo
everytime i try to update redbar reach atleast 99% and stays there for hours, i try installing manually into the directory and still nothing. i also lost my OEM original stock tune. i have a 2005 Chrysler 300c 5.7. My intune is currently on Firmware application 1r02d.
Where can I download the latest version of Data Viewer for my Intune?
Biggmc
hey guys, do i need to relaod factory setting back into truck to download up dates.
I would, just to be safe...
does anyone know how many pre set tunes there is for the 3.5 liter h/o charger 06 in calgary alb canada
Hello Mike, have a little problem whit my intune,after update firmware (1r03h) i check update tune for my mustang and now exit this frases:
An Error occurred lease contact support
Calibration ID:FBLF152. status error
please contact tech support for help
THANK YOU
THANK YOU
I just bought a i-1000 and updated it to 1r03h and tried to use it on my 2009 mustang bullit and it says that my vehicle is not supported. please help
please start a new thread and post a copy of the info.xml file from the intune drive.
i have problems with my intune, i need your help for register mi intune
drag/drop the attached file to the intune drive and allow the tool to import it, and the tool will be registered.
- registration.itf
- (858 Bytes) Downloaded 856 times
