shift firmness and shifts points for 2007 300c AWD
cars10000000
when it comes to the shift points and shift firmness, with the 93 and 91 tunes stock and 6000 rpm are ok, but 6400 rpm it cuts off the throttle, wait a couple of seconds then shifts very smoothly. And with the factory modified tune, when i used increased shift firmness it will shift from first to second, but it will wait a couple of seconds then shift smoothly, then when it comes from shifting from 2nd to 3rd i have to left off the throttle, wait about 3 seconds, then it will shift, but smoothly for all three shift points...plz help. i meant to put this on the dodge gas predator forum not the trinity forum
Re: shift firmness and shifts points for 2007 300c AWD
you need to raise the rev limiter for use with the raised shift points.
