ST7149 DETINATION 2006 mustang GT
I got a (all steeda) CAI under drive pulles axle back exhaust and a intake spacer and then your tuner . At 4000 rpm to red line i get detination and white smoke .I have tryed to advance and retard it and there is no differenc with 93 octane fuel. I am not very happy with this ,i called Steeda they tryed to sale me a SCT tuner with out trying to fix my promblem.
RE: ST7149 DETINATION 2006 mustang GT
Which CAI do you have?
You may need to get a custom tune from one of our dealers to support all of those mods. You can try www.BamaChips.com
Christy High
lurker.
lurker.
Are you 100% sure you have the Steeda CAI tune installed?
Options/show last tune written
Maybe the intake spacer is not fully sealed and is leaking?
Maybe there is a leak after the MAF?
Something is not right....basically you are saying it runs like s*** with the stock tune and the tune that you say is the Steeda tune, and that should not be the case.
Have you monitored knock with the Predator?
Do you get any codes?
detonation problem
You may laugh but check your spark plugs I jave a 2006 GT also and sounds like same problem. I took it to a localtuner and ran it on dyno and found out I had bad plugs. I didnt beleive them but put newplugs in and runs great
2006 Mustang GT C&L Racer Intake Kit
Motoblue UDP
BBK 62mm throttle Body
Motoblue UDP
