More modifiable parameters
sohfast94
Re: More modifiable parameters
Post by sohfast94 »
Well hopefully that fixes it then. That's the problem with the ghost cam, some calids do it better than others and no one seems to have an answer for that at this time. Now on the other hand people "say" they do but once you get down to it and it doesn't work then the story is always the same.
Euterh way like I said your base was a little different from Red Riders I compared them and made the appropriate changes.
Insert Clever comment here...
sohfast94
Post by sohfast94 »
redrider54 wrote:One last request please, could you modify these two, to the cam?
:D
:wink:
93s_cam.frg
(548.45 KiB) Downloaded 303 times
93p_cam.frg
(548.43 KiB) Downloaded 253 times
heli4me
Post by heli4me »
Does the car need to be at idle or certain amount of driving
Time before the car completely recognizes the new tune?
Meaning does the idle lope improve over days as opposed
To hrs?
sohfast94
Post by sohfast94 »
Should be immediate.
redrider54
Post by redrider54 »
Thanks very much for everything!
2013 GT GHIG, Track, Security, Recaro's
Bama Tune via Diablosport Trinity,Airaid Intake,
Lethal Catless X-Pipe,GT 500 Axlebacks w/res delete
Vogtland Springs Whiteline Rear LCA Relocation Brackets
J&M Rear LCA's,JHR Clutch line,Barton Shifter & Mount
sohfast94
Post by sohfast94 »
No problem. Sent tunes to Bama for you as well.
redrider54
sohfast94 wrote:No problem. Sent tunes to Bama for you as well.
sweet, hopefully they can compare them and see what they need to do differently to get it working.
heli4me
Post by heli4me »
sohfast94 wrote:Well hopefully that fixes it then. That's the problem with the ghost cam, some calids do it better than others and no one seems to have an answer for that at this time. Now on the other hand people "say" they do but once you get down to it and it doesn't work then the story is always the same.
OK this file is much better ,there still is some hunting before settling in for the lope but not bad
the LT fuel bank 1 and 2 are still off 1=+10,78 2= -0.78 and they stay the same difference apart
when they change is this normal?
oh i did get some stalling after restart and not let in warm up and this was after a 5 min cool down
let me know what you think at least we are on the right path now :)
Fun4me
Post by Fun4me »
I think that you need a O/R exhaust to run the ghost cam tunes safely.
heli4me
Post by heli4me »
i have attached another file if you could add the ghost cam to this and we will see if acts any different
thanks...
87_Street(1).frg
bama street
(548.24 KiB) Downloaded 264 times
91_Performance.frg
bama performance
(547.91 KiB) Downloaded 254 times
heli4me
Post by heli4me »
Fun4me wrote:I think that you need a O/R exhaust to run the ghost cam tunes safely.
Not according to steeda unless they changed their thinking
But I agree not sure how long the cats will last
Not sure if anybody did a test to verify or it's all
Heresay
sohfast94
Post by sohfast94 »
That is correct.
sohfast94
Post by sohfast94 »
I'm going to have to compare the binary between yours and Red's yours is an updated version of his.
heli4me
Post by heli4me »
Ok
That is why I Sent the other two files
In case the one we are working on has a gremlin
LMK
sohfast94
Post by sohfast94 »
87_street_cam.frg
(548.42 KiB) Downloaded 258 times
91_performance_cam.frg
(548.09 KiB) Downloaded 254 times
Return to “Trinity Ford Gas”
