Datalog
Jamaa
Datalog
Post by Jamaa »
Any expert able to read my datalog and tell me what's wrong?
https://docs.google.com/file/d/0B2oI5FL ... sp=sharing
Thanks!
006_LogMay15_2013_Part_V.log
(512.67 KiB) Downloaded 165 times
sohfast94
Re: Datalog
Post by sohfast94 »
O2's are switching, MAFs reading, trims looks to be in spec. What's the issue?
Insert Clever comment here...
Jamaa
Re: Datalog
Post by Jamaa »
sohfast94 wrote:O2's are switching, MAFs reading, trims looks to be in spec. What's the issue?
Thanks very much for looking at it :)
Car has a stumble/hesitation and it's driving me nuts.
Two weeks ago while on the frwy, car was running pretty bad with a bad stumble/hesitation.
Pulled coil cover and found the plugs and coils saturated in oil. Some coils were damaged/cracked (I posted pics too) and at about this time, I got a CE light P0304 (cylinder 4 misfire). Turns out that #4 plug was rusty and in bad shape.
Replaced the plugs
Replaced the COPs (coils)
Cleaned IAT sensor
Cleaned MAF sensor
Stumble/hesitation persisted and I began to notice a rattle sound that seems to be related to RPM, so I called a tech buddy to come over and plug in his diagnostic equipment. He found bank 2 was lean and the O2 readings were all over the place. Pulled plug #6, checked out the piston (cylinder #6), and it was wet/oily. He suggested replacing the plug grommets/seals for the valve (cam) covers, all the gaskets and suggested replacing that injector as it could be bad.
Sourced a brand new set of 24lb FRPP injectors M-9593-LU24 (yes they're discontinued, but found a whse with a set in stock).
Over the weekend, I did this:
Replaced Fuel filter
Replaced Injectors
Replaced Valve (cam) cover grommets/seals
Replaced Valve cover gaskets (yes the hydroboost was a bitch)
Checked the Cam position sensor, seems good, chains guides and everything in the head seems fine.
Car still stumbles/hesitates
Here is a screenshot of the DV in the dynograph mode and I was not certain if the bank 2 (pink) should be reading like that?
sohfast94
Re: Datalog
Post by sohfast94 »
Chekc O2's for fouling and the TB make sure it's clean. If you ahve oil on top of your pistons you're already not in very good shape unfortunately.
Jamaa
Re: Datalog
Post by Jamaa »
sohfast94 wrote:Chekc O2's for fouling and the TB make sure it's clean. If you ahve oil on top of your pistons you're already not in very good shape unfortunately.
Return to “Predator Ford Gas”
