Mike_Levy wrote:Gotta change the mid-speed fan setting. There is no mid-speed fan. The setting should be the same as the high speed.
Actaully there is, most of us just done use it.
LS is both fans on low
MS is the top fan on high speed and the bottom on low
HS is both on high speed.
Once the top fan kicks into high you can't see or hear very well what the bottom fan is doing, but you should be able to hear it kick into high at the HS setting.
NO, I dont use MS either, I just make my LS setting 5-10 deg less than my MS and HS settings. I set my MS and HS the same just like 99 % of everyone else.
Think I'm wrong? reload your tune with like 140 LS, 155 MS and 180 HS in P
Start your car and watch/ listen while monitoring your temps.
If your car is loud like mine you may want to put some reflective tape on a fan blade of each fan and check the RPMs with a hand tach if you have one. or maybe put an amp meter in series...etc. so you get an indication for each fan motor.
Put your temps back where you want them when your done.
Yeah you gotta be bored or snowed in/ rainy weekend to do this.
