help predator says not compatable with a to 2010 challanger 7136(ver9r07) updated software in vehicle from pcm from 68054123AC-68054123AF for a drivabilty problem (after i reloaded stock tune of course)says i have to down grade to 68054123AE to continue problems is you cant downgrade software on a chrysler pcm
does diablo have a software fix for this to downgrade to AE
thanks for your assistance
help pcm software to new for predator U7136
2005 Magnum R/T 5.7 Hemi
2011 Charger SXT 3.6 Pentastar
Re: help pcm software to new for predator U7136
The Predator is dead. It was replaced by the inTune. There won't be any more updates for it. Either do the downgrade or you'll have to step up to a newer tuner. Chrysler PCMs can absolutely downgrade. DiabloSport has been doing it for years. The programmer should ask if you want to downgrade, and then tell you to open DSDL and hit the button.
it doesn't just says to downgrade to AE and i know the predator is dead but this is the boss's programmer and carMike_Levy wrote:The Predator is dead. It was replaced by the inTune. There won't be any more updates for it. Either do the downgrade or you'll have to step up to a newer tuner. Chrysler PCMs can absolutely downgrade. DiabloSport has been doing it for years. The programmer should ask if you want to downgrade, and then tell you to open DSDL and hit the button.
had to reload ver.9r07 from here on the forums, and update. now programmer working just fine, and back dated software from 68054123AF to 68054123AE.
