Is there a secret?
Tweaked
Is there a secret?
Post by Tweaked »
Is there a secret to getting the Intune to consistently detect the ECU? 9/10 times I plug this thing into my car it can't find the ECU. I would like to datalog, but I don't have time to sit there for a half hour just trying to get this thing to connect.
P.S. Will the Intune datalog the stock tune? I ask because this means that the intune is unmarried.
Re: Is there a secret?
sounds like you may have a cable/connectivity issue.
you can log any tune, stock or otherwise :)
Tweaked
Post by Tweaked »
mikel wrote:sounds like you may have a cable/connectivity issue.
I just got this back from RMA where they replaced the OBDII socket. What else could be wrong if it has a new socket?
I don't think its the inTune. If the socket was just replaced, and the cable is good, the problem has to be your car.
got another vehicle you can try it in?
Tweaked
Post by Tweaked »
mikel wrote:got another vehicle you can try it in?
Only my wifes 2011 Avenger.
it should connect to that for logging or codes...
Tweaked
Post by Tweaked »
mikel wrote:it should connect to that for logging or codes...
Ok, I'll give that a try tonight. Could the problem be that I have a stage 1 computer instead of stock?
not likely....
