NEW TO THIS NEED HELP.......
JJTOWING
Post by JJTOWING »
MY INTUNE READS CAN BACK UP PCM..........SECOND PROBLEM CANT DO ANYTHING WITH IT ON MY COMPUTER.
TRUCK 2001 DURAMAX LB7 CAB CHASSIS
COMPUTER LENOVO RUNNING WINDOWS 7....
PLEASE HELP.
Re: NEW TO THIS NEED HELP.......
what is the error exactly?
JJTOWING
Post by JJTOWING »
orginal pcm back up fail. from truck. 2001 duramax LB7 tow truck
from computer reads error contact diablosport.com
Cailbration ID ODAL1F9
JJTOWING
Post by JJTOWING »
YES I DO HAVE A STEREO in this truck it is un hooked and un plugged.
lots of scanners but all run seperate wiring nothing into factory harness.
odal1f9 is an F150 calid....did you try it tune an F150 with this?
On the duramax, the stereo is not the issue itself, its the aftermarket harness used to tie the harness into the factory harness...remove that and it should work.
JJTOWING
Post by JJTOWING »
IT is ok thank you i will be returning product and going with EFI but thanks anyways. too much trouble here removing everything out of truck hook battery charger and all. thank you for all the help
Sorry to hear that. The flash issues on these early trucks have nothing to do with what you flash with, its the truck itself. You will run into the same issues with any other flash tool most likely.
