I have a 2005 dodge magnum rt
Completely stock other some flowmaster super 40 mufflers, BBK 85mm throttle body, BBK Blackout Series Cold Air Induction
I just got the Intune today and I plugged it into my computer and when the file opens with Autoplay there is no .exe file for the updater.
I have searched the boards here and cant find any help that has worked.
There is no information in the Logs folder or the Tunes File.
There is a file called DIABLO-cd.iso.pz.....when I select it windows tells me there is no program to open it
There is a file called FileIntegrity.DB3.pz....when I select it windows tells me there is no program to open it
Here is what the Info files says.......
<?xml version="1.0"?>
<tool_info>
<main svn="5947" sw_rev="1r03h" full_version="InTune-1r03h 02/25/2013 05:23:14 PM"/>
<registration status="0" sn="J24I387-4"/>
<cal_id CM1="04896395AHke0r0" PCM="04896405AL"/>
<restore bc="0" vin="2D8GV58205H123742" id="0"/>
<system_db vin="1r01c" dtc="1r01a" info="1r01b"/>
<db pid="1r01a" tune="1r01b" mfr="DCX"/>
<db pid="1r01a" tune="unknown" mfr="FORD"/>
<db pid="1r01a" tune="1r01q" mfr="GM"/>
<license tuned="0" avail="1"/>
<unsupported vin="2D8GV58205H123742" oem="DCX" calid="04896405AL"/>
<updates count="0"/>
<oem tool_oem="DIABLO"/>
</tool_info
This is all the info I have that I am aware of..Im new to these Car Tuners but its weird how I bought this and it basically doesn't work yet anyways.
Any information I would appreciate. I will be calling to try to get help with this but I wanted to post it to see what help I can get.
Missing the .exe file to update for first time
Re: Missing the .exe file to update for first time
the auto play should be the updater, what happens when you let that run?
you can delete the .pz files.
when autoplay comes on there is two options to choose from...first one says open folder..when i select that thats when i see the folders..logs and tunes...those .pz files and info....the other option just say....you this device as a file backup...thats all i can select from.....i run windows 7 64 bit
and i there is no cd rom option when i go to my computer either....is there a disk that should of came in the box ?
i tried hooking into my car but of course the device says i need to update after it took info from my cars computer
whiteboy5735
<tool_info>
</tool_info
Thanks[/quote]
DID U EVER GET IT FIXED? ME SAME BS GOIN ON
<tool_info>
</tool_info
Thanks[/quote]
