'13 MDS wont turn off
Re: '13 MDS wont turn off
tacamo01 wrote:Well this AM I put the car back to stock. Original backup loaded just fine. Drove around and then disconnected the battery for 30 minutes. I checked the website for updates again and it only transferred two crom files. Images and loader. No others. I loaded the 91 Octane tune back on this time with parameters adjusted after the tune loaded. I adjusted the MDS to disable and throttle response to 18%. Attached file. The MDS stayed on while in Drive not autostick. You can definitely tell on my car. However, when I put it into autostick and started out in 1st through 4th at 40mph no MDS. I then got up to 45 -50mph and put it into 5th and no MDS. This did not work yesterday with the 93 tune as I tried autostick and normal drive and MDS came on with both. Now this may sound dumb, but I use autostick more than D for drive. So most of my driving will be on 8 cylinders and when I go on long trips I can benefit from the 4 cylinder mode. I do not think it is supposed to work like this but I like it. Anyway, any time there are new tunes for a car, no matter what the car, there is a learning curve. I learned this from my 11/12 Mustangs
mds off here.
pcm_68171355ac_perf_91oct_mds_off.drg
(69.25 KiB) Downloaded 399 times
anyone else who would like it disabled, please post up the LTW :)
GTFODodge
Post by GTFODodge »
mikel wrote:
tacamo01 wrote:Here is a copy of the last 93 tune on the charger with MDS set to off. (But stays on)
PCM_68171355AC_Perf_93oct_modified.drg
give this a shot
Will that work for all trinity tuners or is it married to tacamo01's?
dtru1222
Post by dtru1222 »
lol no love for the OP? My tune is on the first page.
Ufoldfirst
Post by Ufoldfirst »
dtru1222 wrote:Nugzo,
My car feels like a true 400 HP car now... thats the positive side. For the automatics it makes a huge difference, cant say for the manual.
Before the tune the best 0-60 I ever got was a 5.1 and that was only one time. I usually pull a 5.3 to 5.6. The first and only time I tried after the tune 5.07.
I will try to upload the file soon
dtru1222: you didn't state what vehicle you have.. charger/chall/300?
garrett
Site Admin
Post by garrett »
dtru1222 wrote:Ok this is the last tune written
Dtru1222, here's the tune with MDS OFF
pcm_68171360ac_perf_93oct_mds_off.drg
(69.24 KiB) Downloaded 679 times
OK, if your MDS wont disable, restore the stock tune, load this update, and it should be fine :)
trinity_dcx_gas-1t10ba_update.crom
(4.53 MiB) Downloaded 861 times
tacamo01
Post by tacamo01 »
MDS is off. No vibration in the cabin!!
13 Charger R/T Daytona
dtru1222
Post by dtru1222 »
My bad, 13 Challenger RT
dtru1222
Post by dtru1222 »
Thanks I will try it out
dtru1222
Post by dtru1222 »
After another gut wrenching moment... my MDS is finally turned off.
For the second time, in the middle of storing my original back up, the trinity and my evic freezes. Says to turn the key off but when I do nothing happens, the trinity still says turn key off and the dashboard stays lit up like the car is on. Eventually the dashboard turns off by itself and I have to unplug the trinity in order to get my car to respond. After I plug the trinity back up everything loads and its fine but its a scary moment.
Mike, I have a video of the problem if anyone is interested in seeing it.
garrett
Site Admin
Post by garrett »
dtru1222 wrote:After another gut wrenching moment... my MDS is finally turned off.
email me the video. [email protected] Thanks
this was with the new update?
FWIW, you can;t really cause an issue when saving the backup, if that keeps you from wrenching your gut :)
x4x
Post by x4x »
mikel wrote:OK, if your MDS wont disable, restore the stock tune, load this update, and it should be fine :)
Only for 13
or for 11 +
Only for 13
or for 11 +
this was only an issue for 13 models.
