Are you trying to use it on the same Jeep that you modified the stock tune on?Cyrille wrote:Hello, first time sorry for my english ... thank you to google translator!![]()
I use Diablo trinity for a 2012 jeep friend.
after making adjustments impossible to get into the performance menu it says:
"This tool was used to flash a "unknown tool" with "modify stock tune".
the original backup must be restored to that vehicle before tuning another vehicle is possible"
the info:
options/show information :
serial: 6QEEJ76-4
part : dcx_gas
version : v.1r09i
hardware : TRINITY
Bus: CAN SCIA SCIB VPW
Born : 05/10/2013 27730
Bus test : NOT DONE
Saved Calid : 68041672AE
Saved VIN : 1C4RJFDJ8CC260319
Options/show last tune written :
PCM / Modify stock tune (modified)
PCM / 68041672AE
Vin : 1C4FJFDJ8CC260319
Cyrille
original backup problem
Re: original backup problem
yes that it, i'm working on the same car
Hello,
Does anyone know this problem
:" impossible to do original backup after tuning a same car "
thanks
Cyrille
thanks
Cyrille
Does anyone know this problem:" impossible to do original backup after tuning a same car "
thanks
Cyrille
Did you take this Jeep to a dealer to have work done on it without installing the factory backup?
Best bet would be to give us a call with the tool powered up so we can check it out in the vehicle.
mikel wrote:Best bet would be to give us a call with the tool powered up so we can check it out in the vehicle.
ok i have to find a good translator to give you a call
thanks
jwdemon wrote:Did you take this Jeep to a dealer to have work done on it without installing the factory backup?
no i didn't
