Is it saving the modified Tire Size param between writes?
nuke
Post by nuke »
When scrolling through the param list of a tune, I see that the modified parameters are designated as such by the asterisk in their label. But no matter how many times I change the Tire Size parameter, it is never highlighted with the asterisk when I go back in to change other parameters and reload the tune.
Is this just a bug in the software such that once I have modified the Tire Size, I can leave it alone like the others?
Just to be safe, I have been going in and changing the tire size each time I go in and load/reload a tune, but that is getting old now that I am doing much more testing of different mods and such.
I can live with it not designating the param as being modified as long as it is actually retaining that modification between writes like the rest of the params I have changed.
thanks,
Nuke
garrett
Site Admin
Re: Is it saving the modified Tire Size param between writes
Post by garrett »
tire size is considered a quick adjust, which is set by turning the key on and off. There is no reason to go back to writing it unless you change or restore the vehicle back to stock.
