Is it possible to update this without using the autoupdater. I can easily download anything but the firewall I am set up on stops me from communicating so I keep getting 12002 error when running the auto updater.
thanks
Update my InTune without using the AutoUpdater
bigjay89gta
Re: Update my InUne without using the AutoUpdater
thats a firewall issue, post your info file and we'll see what it needs.
bigjay89gta
Re: Update my InTune without using the AutoUpdater
- <tool_info>
<main full_version="InTune-1r03h 02/25/2013 05:23:14 PM" sw_rev="1r03h" svn="5947" />
<registration sn="J23GQ46-4" status="0" />
<cal_id PCM="05156122AC" CM1="05150730ADke4a0" />
<restore id="0" vin="2C3CCADT2CH163770" bc="0" />
<system_db info="1r01b" dtc="1r01a" vin="1r01c" />
<db mfr="DCX" tune="1r01b" pid="1r01a" />
<db mfr="FORD" pid="1r01a" />
<db mfr="GM" pid="1r01a" />
<license avail="1" tuned="0" />
<unsupported calid="05156122AC" vin="2C3CCADT2CH163770" oem="DCX" />
<updates count="0" />
<oem tool_oem="DIABLODCX" />
</tool_info>
yeah I have tried all i can to get through the firewall. It is only the allow list for both incoming and outgoing allow lists.
any help appreciated.
thanks
</tool_info>
thanks
you need the 1r03p app from here:
http://www.diablosport.com/forum/viewto ... 24#p198024
and the latest tune DB attached.
bigjay89gta
Where do I drag and drop these ?
to the intune drive.
bigjay89gta
ok got those put in and says I might need PCM update to my vechicles VIN# any help with this?
2012 Chrysler 300s 5.7L
save this file to your intune then head to the vehicle.
bigjay89gta
Thank you.
She is up and running.
