06 duramax predator problems
I have a 06 Chevy with a 6.6 duramax. I have had the predator tuner installed for about 3 weeks and this morning attempted to change the tune from towing to 85 hp. The install went as normal until the end when it told me to turn the key off on then back on at which time it said the tune was not installed. It then told me to reboot the tool and then to reinstall the original program which I tried and came up with a message saying that it couldn't be installed. Now the truck has all normal functions except ill will not crank or turn over, dead when you turn the key. Any suggestions?
Re: 06 duramax predator problems
are there any aftermarket electronics, such as radio/trailerbrake/amplifier, on the vehicle? If so, be sure to remove them completely before trying to install the factory tune again.
it does not have any. the tuner is saying Unit 1: error unlock for reflash (1). it a predator U7186
please give us a call with the tool powered up in the truck to further assist you.
I sent the unit along with the ECM to y'all. It was delivered Monday morning. I have emailed and called with no response . Could it be possible to get a status on RMA # 18447. Your customer service has been great I just can't get anyone to answer the phone. Thanks.
[quote][/quote]
[quote][/quote]
Please send an email to Rmastatus at diablosport.com for a status on your computer.
Would like to give out a big Thank You for your help in solving this problem. Your customer service is incredible! Thanks again.
glad we could help.
- [email protected]
Thia is basicly whats going on with mePoach 07 wrote:I have a 06 Chevy with a 6.6 duramax. I have had the predator tuner installed for about 3 weeks and this morning attempted to change the tune from towing to 85 hp. The install went as normal until the end when it told me to turn the key off on then back on at which time it said the tune was not installed. It then told me to reboot the tool and then to reinstall the original program which I tried and came up with a message saying that it couldn't be installed. Now the truck has all normal functions except ill will not crank or turn over, dead when you turn the key. Any suggestions?
[color=#FF4000][size=150][b][b][/b][/b][/size][/color]
- [email protected]
Please any help ??? Hello please ??
