trouble with 2013 Durango R/T
alengineer
Re: trouble with 2013 Durango R/T
Post by alengineer »
any update regarding ABS light ???
alengineer wrote:any update regarding ABS light ???
thats been fixed for quite some time now :)
TRAUMA
Post by TRAUMA »
how would anyone know? How did you communicate this fix?
does "fix" mean going forward it wont break peoples ABS light? Or it will also finally shut off those ABS lights that have been on for 6 + months?
clearly, you need to do better at documentation and communication, every other vendor does it and for things that cause much less (and less expensive) havoc to peoples hard earned belongings
I can full-bare metal rebuild a pc in under an hour yet I STILL get and read detailed notes about every minor update available for my hardware and software
I cant rebuild my Durango or PCM at all so I need clear and detail comm's from diablo or I can never confidently use or recommend your products... just to get an ("alleged") 20 more HP...or higher shifts... and neither will any other sane vehicle owner
seriously are there even any fixes in these updates, or just more supported cars?
TRAUMA
Post by TRAUMA »
garrett wrote:have you updated the tool recently? You can set the tire size back to the factory tire size, using the tool.
most recent update installed
tried changing tire size to OE spec, nothing else -fail (change supposedly pushed, according to the trinity, but ABS still comes on)
then tried 93 octane tune + OE tire size - same result
this is clearly a long term known... issue I can google threads going back years with diablo ABS issues poppin up everywhere
u guys really need to invest more time and manpower into QA/Dev/Testing especially regarding ABS issues... and more $$ into permanent test vehicles. can you not afford to lease 1 of every current supported gen of vehicle to have them on hand until
all bugs are sorted? How can I trust you to support a product that you cant even regularly dev or sandbox on a real vehicle?
TRAUMA
Post by TRAUMA »
fixed = "people stopped responding to their own threads asking for updates, the issue is still present, just the people with the issues went away"
unless you have some new secret unreleased code somewhere that's not public, nothing is fixed - using most recent I have same issue
azjeeps
Post by azjeeps »
TRAUMA wrote:same here - just installed diablo 93 octane tune, and
set tires to 22" - test drove with ABS light on
restored backup, ABS Light remains
do i try the file u posted? i updated my trinity last night to newest
auto-update version available
Hey TRAUMA, after reading your post here, do you actually have 22" tires, or 22" rims? Have you took a tape measure out and measured the diameter. It's just that a 22" tires seems really small for a truck type vehicle. They came stock with a 20" rim on some and a tire size of about 30".
2013 JKU 10th Anniversary Edition
3.5" Lift, Banks CAI, Custom Flowmaster Cat-Back exhaust, 315/70 R17 Tires.
alengineer
any good news
