08-13 Avengers....
Vehicles needed for testing
untouchable4206
Re: 08-13 Avengers....
Post by untouchable4206 »
BTW, am I the first to have the tune, except for the project vehicles?
Modern Muscle TB
Ported Intake Manifold
Apexi N1 Full Exhaust
Resonator Delete
Ram Air Intake
DS18 Audio
PowerStop Zinc Drilled Rotors
H&R Springs, Custom Shocks
Oil Pressure, Oil Temp,
Air Fuel, Volt Gauges
Zex Nitrous
Rear X Brace
Rear Tie Bar
Sport Club Seats
4 Point Harnesses
red91rt
Post by red91rt »
untouchable4206 wrote:BTW, am I the first to have the tune, except for the project vehicles?
Not sure--depends on what time you did it tonight. :P
I got the trinity. I seemed to have no problems. I have a 93 tune available too. So far only tried out 87 because I have 85 half a tank (I am at 4500 feet elevation so kind of getting away with it.)
Noticed the same--tears it up. It's definitely something you can feel, not just a spare tenth or two at the strip but in all around how it drives.
I did not really notice all that much throttle response using 10% throttle boost, but at 20% throttle boost in manual adjustments I definitely can notice it. I played with enrichening a bit. Played with spark a bit. Lots of neat toys.
Noticed one thing cool using the gauges on the Trinity: On a 44 degree night driving around with engine fully warmed my home-built cold air intake really is cold. It was producing a windchill when cruising and even more so when accelerating. :twisted:
LOVE IT Mike. Can't wait to report on ET's. Frankly, as mentioned in the liability clauses on the device, there's nowhere safe around here to try out the 1/4 mile race mode. Even before this tune at 4200 feet above sea level I was turning 90 or 91 MPH at end of 1/4...if I'm a couple MPH up from that now I really don't want to risk an impound (and, honestly I detest street racers.)
untouchable4206
I only seem to have the 91 octane, 87 octane, Diablo tune, and modify stock tune. No 93 tune, WTH!
No 93 Tune??
No 93 Tune??
Modern Muscle TB
Resonator Delete
Ram Air Intake
DS18 Audio
Zex Nitrous
Rear X Brace
Rear Tie Bar
Sport Club Seats
4 Point Harnesses
red91rt
Post by red91rt »
Mmmm...now that you mention it, it's possible I wasn't paying attention close enough and I only have diablo tune on top as well. I'll check in the morning. I was/am very tired from long day at work and knew I could only play with 87 tonight anyway since I have crappy gas in the tank.
P.
dusterman
Post by dusterman »
My 2014 avenger ran great last night now its running like crap. No throttle input at all and got a code for p0506 idle control system. I now am putting my car back to stock tell you fix these issues.
93 tune is the diablo tune....
dusterman wrote:My 2014 avenger ran great last night now its running like crap. No throttle input at all and got a code for p0506 idle control system. I now am putting my car back to stock tell you fix these issues.
did you make any adjustments?
there is an issue with the neutral rev limit on the newer cars it seems, and adjusting that may cause issues ;)
Tech_Vance53
Post by Tech_Vance53 »
So, I have a question. Would I be able to "test drive" the tune? My dad has a trinity for his C6 Vette, and it's in the garage for the winter. Would I be able to take the tune off of that, update the tuner, then put the tune in my Avenger, and then undo it all and retune the Corvette when I can afford mine next week?
(I know I said I had cash in hand to buy them, but I found these wheels for sale, and they were just so pretty)
Tech_Vance53 wrote:So, I have a question. Would I be able to "test drive" the tune? My dad has a trinity for his C6 Vette, and it's in the garage for the winter. Would I be able to take the tune off of that, update the tuner, then put the tune in my Avenger, and then undo it all and retune the Corvette when I can afford mine next week?
what year is your avenger?
Tech_Vance53
2012
2012
no, you'd need an I-1000-DCX or Trinity for your 2012 model.
red91rt
Post by red91rt »
Sweet--thanks Mike for confirmation on Diablo tune. Forgot to even look on way in this morning. But! I did do one 1/4 mile trial. Where I was at 15.45 to 15.65 in October on E85 tune at 4200 above sea level, the race mode told me this morning I'm a 15.25 on 85 octane pump fuel and the 87 tune with some adjustments. If that's even remotely accurate (which I'm starting to think it is by the seat-of-pants you can actually feel) I'm very, very pleased. I should be able to finally break into 14's with E85 at this elevation. ...Makes me want to go back to Sacramento drags this Summer and see what it will do a little lower down the hill.
P.
red91rt wrote:Sweet--thanks Mike for confirmation on Diablo tune. Forgot to even look on way in this morning. But! I did do one 1/4 mile trial. Where I was at 15.45 to 15.65 in October on E85 tune at 4200 above sea level, the race mode told me this morning I'm a 15.25 on 85 octane pump fuel and the 87 tune with some adjustments. If that's even remotely accurate (which I'm starting to think it is by the seat-of-pants you can actually feel) I'm very, very pleased. I should be able to finally break into 14's with E85 at this elevation. ...Makes me want to go back to Sacramento drags this Summer and see what it will do a little lower down the hill.
P.
Nice!
dusterman
Post by dusterman »
Yes I did on the rev limiter.
neutral rev limiter?
that seems to be broken, leave it alone for now ;)
Locked
