2014 Sierra Tune with results!
ziknazoo
Post by ziknazoo »
If you read nothing more of this post, let it be this... If you have a 2014 GM truck, you NEED an Intune....
I bought my 2014 Sierra 1500 SLT 5.3 3.42 rear three months ago. While I generally liked the truck, the poor throttle response and mushy shifts were maddening. After much thought about voiding my warranty, I decided I had to do something about it. So, I ordered an Intune.
It arrived and I spent a few hours trying to get it to update :x . Finally, I used a different computer and it reluctantly updated after a few tries. But, man did it take a long time!!!! Preparing/writing/preparing etc for almost an hour!
With an updated Intune in hand, I went out to the truck and loaded the 87 octane tune with the firm shift TCM tune. The only thing I changed from the canned tunes was throwing in 15% off throttle boost.
The tune installed without a hitch and the truck was immediately different... In a good way. Throttle response was substantially improved, shifts were quicker and more positive while still being very comfortable.
I drove around I bit with a grin on my face :D and decided to make a few changes. I went 7% softer on the 1-2 shift to make it more comfortable. I also bumped firmness on the WOT shifts by 5% because I thought they were still a bit soft.
The truck seems noticeably quicker, and more responsive. I get some very minor pinging for a second or two if I mash it. In my mind this means the wizards at Diablo pushed the tune right to limits of 87 octane and left nothing on the table. This is in no way a negative if you ask me. Gas mileage has not suffered. In fact, it seems slightly better around town... Maybe because I don't need to mash the throttle trying to get some response out of it.
OK, so I promised results... Using my iPhone's Dynolicious app (rollout turned off), I ran 0-60's with the stock tune vs the new tune. With the stock tune, 0-60 was a very consistent 7.5 seconds. With the Diablo tune, 7.2 seconds. That's not a "best time" either: that's an average! It's very consistent.
I can't help but wonder how it would be with the 91 octane tune. But we don't have 91 around here, only 93 and it runs over $4/gallon... Maybe one day I'll treat her to a tank of 93 and try out the 91 octane tune.
The only thing I'm wondering, is what effect elimination of torque management has. What would be the effect on the truck? I don't want to keep programming it over an over with endless experimentation.
Cheers!
John
Re: 2014 Sierra Tune with results!
good to hear.
as for the TM, it leads to better shift feel, better throttle response, and lets you put that power down in the low speed/low rpm ranges :)
2012_z71
Post by 2012_z71 »
I just installed my new inTune today. I had a faulty one before this and I must say, this one ran a lot smoother. What would your reccomendations be as a starting point? RPM, shift firmness and so on?
2012_z71 wrote:I just installed my new inTune today. I had a faulty one before this and I must say, this one ran a lot smoother. What would your reccomendations be as a starting point? RPM, shift firmness and so on?
best starting point is how we deliver the tunes.
if you feel you want or need to make changes, make them in small increments, one change at a time to see what works for you.
2012_z71
Post by 2012_z71 »
Thanks Mikel! I'll probably play with it a little bit more as I go this week.
This might be a really silly question but what does WOT mean? Is it Wide Open Throttle? :shock:
yes.. WOT = wide open throttle, get on it, pedal to the metal, put your foot to the radiator, etc etc.. :lol:
shore
Post by shore »
Got me a intune on my 2014 gmc and when it starts downloading it says error cant read the computer can somone help
shore wrote:Got me a intune on my 2014 gmc and when it starts downloading it says error cant read the computer can somone help
did you updaste the device first?
can you post a copy of the info.xml file from the intune drive?
shore
Post by shore »
How do u update it mike and thank for the reply
shore wrote:How do u update it mike and thank for the reply
plug it into a pc, let the auto update run, and it will update itself :)
shore
Post by shore »
What if my truck had a recall and took it to the dealership would that update still work
Yes, the recall calibrations have been added.
shore
Post by shore »
Ok thnk u let me try it
shore
Post by shore »
Mike the update starts and finishis and a message on the bottom that says DO NOT UNPLUG updates loaded to intune it will reboot automariclly but I stayed 45 minutes and nothing is it normal or what
shore wrote:Mike the update starts and finishis and a message on the bottom that says DO NOT UNPLUG updates loaded to intune it will reboot automariclly but I stayed 45 minutes and nothing is it normal or what
did the tool reboot and start updating?
