wideband 02 sensor: challenger rt
macedo6466
Post by macedo6466 »
Wondering.. Is there any benefit utilizing a wideband 02 sensor on a stock Challenger RT?
Re: wideband 02 sensor: challenger rt
Only if you really need to see the AFR ;)
macedo6466
Was curious since it would get a broader band in readings.
macedo6466
Just made some modifications to my Challenger RT and will be needing a Wideband 02 sensor.
Is there a Wideband that is compatible with the Trinity?
I just seen the Trinity with wideband 02 sensor display.
Where can I get this wideband to hook up to my Trinity?
Any wideband with an analog output will work.
macedo6466
for a V8 would you recommend (2) WB02 sensors or one will suffice?
Since its just for monitoring, one should be fine. The banks should be pretty close. If you were running the motor off them, or were running a split intake manifold with forced induction, then I would say one for each bank.
macedo6466
Thanks Mike. :D
Your the Man!
No problem. 8)
Return to “General Questions”
