I have a 2013 Challenger v6, all I get when trying to update is contact Diablo with my cal ID. and I guess it didn't register as well
Any help would be appreciated.
<main svn="7429" sw_rev="1r03x" full_version="InTune-1r03x 03/25/2014 02:04:19 PM"/>
<registration status="0" sn="KUD0EC4-8"/>
<cal_id CM1="05150808ABkc3l0" PCM="68171377AA"/>
<restore bc="0" vin="2C3CDYAG3DH704209" id="0"/>
<system_db vin="1r01c" dtc="1r01a" info="1r01b"/>
<db pid="1r01b" tune="1r01n" mfr="DCX"/>
<db pid="1r01b" mfr="FORD"/>
<db pid="1r01a" mfr="GM"/>
<license tuned="0" avail="1"/>
<unsupported vin="2C3CDYAG3DH704209" oem="DCX" calid="68171377AA"/>
<updates count="2"/>
<oem tool_oem="DIABLODCX"/>
Need to register
Chuckbrewer
Need to register
Chuckbrewer
Re: Need to register
Here is the xml file. hope I did right.
- info.xml
- (1.89 KiB) Downloaded 316 times
looks good, just save this to the intune drive to register it.
- registration.itf
- (862 Bytes) Downloaded 368 times
Chuckbrewer
I moved that file into the unit and the unit reboots and I get the error saying to contact you guys. here is the new xml file. looks like the registration is now a code 1. I hook it up to my car it says needs more updates.
- info.xml
- (64.54 KiB) Downloaded 339 times
Chuckbrewer
Updated the dcx manually to the" diablodcx-dcx_tunes-1r01j.itf" then it auto updated it to N. when it rebooted I still get the same contact support. When I hooked it up to my car and hit the X ,when it said I needed to update, it says my car is not supported.
Here is the updated file.
Unsupported VIN in the file???
- info.xml
- (64.54 KiB) Downloaded 341 times
gotta click the check when it asks you to check for an update...
Chuckbrewer
Yea, did that multiple times already and always go the same contact tech support on update. Found out the reason this morning from support.
It seems the calibration on your vehicles PCM isn't one we've seen. I'm sending this over to our tuning staff to have them take a look at it and add it in the next software update.
Thanks for the help an great response. Now just have to wait on an update.
I am having registration problems as well.
Here is my info file.
- info.xml
- (1.74 KiB) Downloaded 311 times
I went ahead and activated it for you.ksigfuss wrote:I am having registration problems as well.
