traction control
grizzly660
traction control
Post by grizzly660 »
I was just wondering went I disable the traction control with the hemifer tune with the trinity is this normal for my regular push bottom for the traction control the light to come on! Because went disabling the traction control with the trinity all the lights stay's on ABS,EMERGENCY Brakes etc. for a couple key cycle and all the lights goes off. But went pusching the regular button the light comes on for traction control off. Or do I have to disable it every time with the trinity went the light goes off went I want it disable again.
Re: traction control
when using the tool to disable, it truly disables everything related to esp, including ABS, so thats normal.
circleD212
Post by circleD212 »
Why will my tuner not update the pcm when I try to disable my ESP. I have a 2012 SRT8 and It keeps failing to update the PCM.
gregzbobo
Post by gregzbobo »
I also disabled traction control on my '12 Avenger 3.6, the idiot lights came on, and I decided with it raining around here I better just leave it enabled, so I re-enabled it. Well, the traction control idiot light stayed on and the dash button does nothing. So I restored the original backup, and the traction control idiot light is still on. So I unplugged the Trinity, then disconnected the battery for a while, reconnected it, and the ETC fault light is still on and the dash button still does nada...
2012 Dodge Avenger 3.6: Mopar CAI, Corsa cat-back exhaust, various other non-performance mods/upgrades.
what does it say when you try to enable it in the device?
gregzbobo
Post by gregzbobo »
CANCEL
ENABLE
DISABLE
I've tried disabling and then re-enabling in a tune then restoring the original backup, no joy. Disabling causes the ABS and the traction control light with OFF under it to also light. The one with off used to only come on when I pressed the traction control off button on the dash. The dash button does nothing now BTW. I've received a response on my support request from Garrett, so hopefully we can figure out what's going on.
