ABS light always on
fastdude007
Re: ABS light always on
Post by fastdude007 »
Did not use setting for the tire size
WinterChill
Post by WinterChill »
I am having this same issue. I have a 2013 Jeep Grand Cherokee Overland AWD. Bought unit because I needed to change tire size since I got larger tires. Installed tune, changed tire size then ABS light came on immediately. Found this thread, put stock tune back on, ABS light still on. Updated Trinity to trinity_dcx_gas-1r11e installed tune and ABS light is still on. I called support on 5/27/2014 and was told I would receive an email on what to do, still have no email and have ABS light on!! I am leaving stock tune on for now. Have a $600 paperweight. If not resolved I will return it!!
WinterChill
Any updates on this issue? I changed tune to 93 oct and was throwing codes yesterday, my service 4wd light and check engine light came on, my blind spot monitor, forward collision, speedometer all quit working!! . Went back to stock. The codes were cleared doing this but my ABS light is still on!! Please help!!
WinterChill
DiabloSport support must be asleep at the wheel..... :drivingbad:
Guess I will return this crap - buyers beware!!
please try changing tire size with the 1r12 and see if it goes out.
cq842000
Post by cq842000 »
mikel wrote:please try changing tire size with the 1r12 and see if it goes out.
Well I have an Intune DCX, and a 2012 Charger and I can confirm having the loss of comms errors as well as an ABS VIN mismatch code and I didn't even use the tire adjustments parameter. I hope this gets the focus it deserves, gets identified, and fixed as I won't chance tuning again and having yet another PCM replaced. Its kind of weird that this is a higher tiered scan tool as well yet it cannot read stored codes that the dealerships can definitely see. There really is no telling how many actually have this problem or a similar one (which does not set a dash light aside from the ABS light for the jeeps) and they won't know until the dealership tells them they need a PCM replacement.
I thought it was a little weird when the DS rep told me they had never seen this kind of issue before and yet here it is.
sarah_ima64
Post by sarah_ima64 »
I had the same issue like you, 2005 ram 1500 daytona, my dealer only reprogram gear ratio differential, and then I never changed adjustment tires.
2005 RAM 1500 Daytona : Diablosport Trinity, CAI Airaid, Headers JBA, Catback Borla.
2009 RAM 1500 SLT 4x4 : Diablosport Trinity, CAI Airaid, headers JBA, Catback Flowmaster.
2011 RAM 1500 Laramie 4x4 : Diablosport Trinity, CAI Airaid, Catback Magnaflow.
BlackOverlandHemi
Post by BlackOverlandHemi »
Did anyone here get their ABS Light fixed?
wrtiii
Post by wrtiii »
Has there been any updates on the ABS Light issues?
