pentastar 180 thermostat fan setting
I am about to install my new 180 thermostat to my jeep jk 3.6, can you please advice me what is right fan setting for the new satat? the stock thermostat is 209 F and the new one is 180 F, should i lower all of the fan setting by 29 degree or what you recommend me to do?
thanks
thanks
Re: pentastar 180 thermostat fan setting
lower them all by the same amount, about 20*
Hi mikel
i thing the fan setting not working in my 2013 jeep!!
any idea?
any idea?
a fix is coming shortly...
Mike,
I'm very interested in this fix as I've got the RIPP Mods 180* thermostat and am ready to install it in my 2014 Charger 3.6L Pentastar.
Any ETA and where will you post info when it's ready?
Also, will the original OE tune need to be reinstalled in order to update the Trinity?
Scott
Scott
The charger stuff was working fine, this is specific to some Jeep applications.westsdad wrote:Mike,
Scott
any ETA mikel?
i really need this asap
try this update, should be fixed here.Yes wrote:any ETA mikel?
mikel wrote:try this update, should be fixed here.Yes wrote:any ETA mikel?
Thanks Mikel, you're the man
TESTED,
Sorry mikel, its not working
I tested as well on 2014 Jeep Grand Cherokee Hemi. It did NOT work.
please, give me a little more info than that
are you sure its updated?
what exactly happened?
What does not work?
What does not work?
yes, updated 1t12bbmikel wrote:please, give me a little more info than that
What does not work?
i set the fan as the following
all LS 189
all MS 192
all HS 194
what happend is the the HS & MS will not work until 229
I'm guessing these fan adjustment numbers will work for a 2012 JKU right? I have the 180* stat in route today...
Do i need the update posted above or will the "mega crom" 1R12 work for me??
2012 JKU RUBIKONG: Far too much to list here...
any news?
