I 1000 failed group update
I had recently went to update the tuner for the truck I have which is a 2014 Ecoboost. Let the tuner run and it went through the update writing and verifying and then it was finished. At the end it read a error stating it failed the group update 5 or something of that nature. I plugged it into the truck and it recognized but it never gave me a prompt to chose download the cal from the internet. I went through the tune menu when you can chose the tune you wish but when it went to start as I stated it did not ask for connection for the internet it went right to telling me it was going to read the original cal. Please advise if there is something I can do to restart. It will not update again it tells me it is up to date. Any idea's?????
Re: I 1000 failed group update
run the updater again and it should correct itself.
It did not work. I tried that multiple times, I went a read down some and found a post where you posted the file. http://diablosport.com/forum/viewtopic.php?f=45&t=48482 and loaded that then proceeded to run the updater and let it update all the firmware and the boot loader and the rest of the info your update was to add. The error is gone and the tuner worked fine after. But if I did not have the file I would have been dead in the water. It updated in sequence multiple times. Thanks for the reply.
