Need some help one predator, two computer
Brian2797
Post by Brian2797 »
I took out my stage 1 ecu with a cmr tune it, I replaced it with my stock pc to get it to pass emissions. I had a cmr tune put into the stock ec to disable the misfire code to get the car to pass emissions. I took the stock ec back in the car without installing the original backup. I've tried everything. I can't get the predator to let me reinstall the original backup on either ec's. I have both original backup files on my laptop. What do I need to do? Do I need to put the stock ec in the car and have I re-flashed, then pull the original off of it, and then reset the tool? Any ideas??? Thanks
Re: Need some help one predator, two computer
on the tool, options/show last tune written, what does it say on the next screen for VIN and calid?
thats the PCM its married to.
Brian2797
Post by Brian2797 »
My mistake, this needs to be moved to the predator section.
Brian2797
Post by Brian2797 »
mikel wrote:on the tool, options/show last tune written, what does it say on the next screen for VIN and calid?
It says , "predator not married yet. Nothing to show""
Brian2797
Post by Brian2797 »
If I go to the next screen it shows me my vin number and pcm number. The pcm number matches the backup file that I have on my laptop.
Brian2797
Post by Brian2797 »
it says not married, then the next screen shows vin and calid??
Brian2797
Post by Brian2797 »
mikel wrote:it says not married, then the next screen shows vin and calid??
If I select show vin, and show calid? Yes, it's shows me both.
no, under options/show last tune written sir.
Brian2797
Post by Brian2797 »
mikel wrote:no, under options/show last tune written sir.
not married
but does it show the vin and calid on the next screen sir?
Brian2797
Post by Brian2797 »
mikel wrote:but does it show the vin and calid on the next screen sir?
If I select last tune written, it says," Not Married"
I think I will call into tech support on Friday. I will have my laptop, and both ec's with me at the time. Hopefully that makes it easier.
