Intune failed to load l, stuck in recovery, truck will not s
LAMICA
Post by LAMICA »
Hi
I have a 2014 ram 5.7 with electronic shift. I tune is stuck in recovery mode and my truck will not start.
I have discounted the battery as some post mention with no luck. I tried updating the unit on the computer again but it is stuck on tune only.
In the truck The Intune loaded the backup but at the last part after 100% I get the failed message
Please help need truck to get to work.
Re: Intune failed to load l, stuck in recovery, truck will n
They're closed... it's the weekend, won't be back in the office until Monday...
LAMICA
Post by LAMICA »
What time zone are they in? Do you know why i cannot start my truck now? Am i able to reset the device through you ? I cannot upload my runtime errors to this post
I have no idea why it won't start... if disconnecting the battery didn't work, then I have no idea.. I'm a GM guy.. and no, I can not reset the tool.. only the diablosport techs AT diablosport can do that... I am about 2300 miles away from where they are located, heh...
and they are in the Eastern Standard time zone... Florida...
LAMICA
Post by LAMICA »
Nice lol. I left the battery cable off overnight. When I hit the start button all the gauges act right but it doesn't want to kick over to start. Checked all the fuses and still nothing. The itune is suck in recovery mode.
Do you think I should tow it to the dealer and get it services under warranty? Or tech support will be able to unlock it on Monday?
Thanks for replying
tech support should be able to getcha going on Monday..
[email protected] or 1-561-908-0040, option 1 for tech support... Mon-Fri, 9am-6pm (EST).
LAMICA
Post by LAMICA »
06MonteSS,
Since I have a push button start is there anything special I need to do?
I push the button to run when the Intune ask for key to on position. Is this correct or should I go to ACC instead?
no idea.. can always try that though.. won't hurt anything to try that...
LAMICA
Post by LAMICA »
NO Luck, my luck lol. Do you think it a registration issue? I originally received the regular intune not for my 2014 truck and newer they i swapped it out for the DCX when there registration window popped up the website stopped working and I never received a authorization email?
Could this be it?
info.xml
(1.94 KiB) Downloaded 315 times
chachi
Post by chachi »
what happened is when u went to load the tune something freezed ur device and ruined ur factory tune. your pcm will need to be sent back to have the pcm restored and loaded with factory tune . unfourtinatly they will know u loaded this tuner to ur car a will charge you to sent it back to stock. that's why u have nothing working in the car..
Please give us a call with the tool powered up in the vehicle so we can get you going.
LAMICA
Post by LAMICA »
Hey everyone,
For anyone else who comes across this issue. Had great help from Mike at tech support, sucks to be 2 hrs behind his time, but he informed me that his manager usually works till 6:30 PM and can be reached at the support email.
I had to email Mike the info file in the last four runtime files displayed on the inTunes drive. I had to get a 911 emergency update file created which I downloaded to the Intune. After the install you'll have to send him the key combo to reset the device. Once I got the password back I was able to restore my vehicle to original tunes and it could start up. After the original back up was installed I installed my tune with no problem.
Thanks for all the help.
Glad to hear it.
Styledogg
Post by Styledogg »
I just got my pcm back and yes sir back in fail mode- I need the passcode to reset my diablo if this can happen I can start my vehicle. my issue is a thread as well
Les
Post by Les »
I got my intune i1000 the other day plug n play so I thought........ stuck in backup mode and car wont start :blowup: tried everything I could find trying to get my car to start. yet it still wont :crashing:
