I own the i-1000 and i' m not exactly sure what the throttle booster is and what i gain from it. What do you recommend for percentage? Will i hurt anything going up to 20%? Faster 0-60 times going up to 20%? Please respond i want more clarification. Thanks
Jeffrey R
2005 Dodge Magnum SXT 3.5L
Throttle Booster
Re: Throttle Booster
I have the same question for the throttle booster option. Is there an optimal %??? Also, the trinity for my JGC hemi does not have an option for firm or normal shifts? Should it?
- racerxtc69
I Think it increases the throttle timing as it kick it in faster
- DaILLestWun
It pretty much increases throttle response. I loved it when I had it on my Magnum. The percentage depends on what you feel comfortable with.
the percentage varies from person to person, as its a personal preference modification. I typically tell customers to bump it up to 20% then back it down until you feel comfortable with the throttle response.
miztercorny02
where can i find this setting? and is this how sensitive the pedal would be or how responsive it will be?
thank you
thank you
This does not apply to calibermiztercorny02 wrote:where can i find this setting? and is this how sensitive the pedal would be or how responsive it will be?
thank you
Insert Clever comment here...
miztercorny02
damn... will it ever be?
