axle ratio
jetskier369
axle ratio
Is there a way to adjust the axle ratio by .01? My 05 mustang has 3.73 gears, and the closest I can get it is 3.69, if I hit the button it says to make fine adjustments it increases by .1 making it 3.79. I can get it close, was just hoping to get it set exactly to it. Thanks.
Re: axle ratio
you tried the fine and coarse adjust buttons?
jetskier369
Re: axle ratio
Yeah fine adjust it by .1, and course by like 1. or something crazy like that. I was hoping for a way to adjust it by .01.
Re: axle ratio
Why would 3.69 even be an option? I've never seen a rear drive 3.69 final drive. It should just have the normal ratios as presets; 2.56, 2.73, 2.93, 3.08, 3.23, 3.31, 3.42, 3.55, 3.73, 3.90, 4.10, 4.30, 4.56, 4.88 and 5.13.
jetskier369
Re: axle ratio
Yeah, it doesn't have preset's. Instead you can adjust it from 1 to 6, and it looks like only at 1. or .1 intervals. With the exception that it goes from 3.6 to 3.69 then back to .1 intervals. And so far haven't found a way to adjust it to 3.73.
Re: axle ratio
export the tunes and post them here and I will fix it for you.
jetskier369
Re: axle ratio
Ok, So I was partially wrong it changes by .5 or .1. Instead of 1. or .1 Here's the original, and what is currently loaded. I wasn't sure which you needed. Thank you for your help.
- PCM_FBJR3G5_87p_modified.frg
- (5.25 KiB) Downloaded 205 times
- PCM_FBJR3G5.frg
- (421.43 KiB) Downloaded 193 times
Re: axle ratio
this is set to 3.73
when you load this file and the tool asks if you want to reset params, click YES, then load this with no changes to axle or tire as its already done.
- pcm_fbjr3g5_87p_3_73.frg
- (960.14 KiB) Downloaded 195 times
