2014 Ram fan always on w/canned 87 tune?
ksrracer
Post by ksrracer »
I loaded the 87 tune and adjusted the throttle response and tire size but noticed my electric fan is running all the time after it reaches temp. It fluctuates 6* from 197-203* going down the hwy in 50* weather. On the stock tune the fan never came on and the active grill shutters would be closed the majority of the time. Also the twmo would run around 204* pretty constant. How much lower is the fan switched to come on on the 87 tune?
The intune has the latest update as of 3/14/2015 and the truck just had all the pcm updates done at the dealer prior to install of said tune.
Re: 2014 Ram fan always on w/canned 87 tune?
can you load the tune and post the last tune written here please?
ksrracer
Post by ksrracer »
Sure I can do that this evening. How do you post the LTW?
ksrracer
Post by ksrracer »
Is this it Mike?
ksrracer wrote:Is this it Mike?
load this up, should be better.
ksrracer
Post by ksrracer »
Do I jus drag this file into the intune tune folder?
just to the drive so the tool can import it.
ksrracer
Post by ksrracer »
This just corrected the fans and left the tune alone right?
Thanks again!
ksrracer
Post by ksrracer »
Mike i uploaded the adjusted tune you posted and the fan is fixed but the performance is down. Feels and shifts like stock. Was anything adjusted torque management wise on this tune? Here's the LTW, maybe something didnt' upload correctly?
all i did was set the fan temps back to stock....?
