won't back up factory settings
chevyguy0487
i have a trinity t1000 and a 2004 chevrolet silverado. went through the process on the computer installing the downloader and letting the tuner update when i go intsall the tuner programme it won't back up my factory settings.. can you help me? also it says can't connect pcm but when i go to options it picks up my VIN.
Re: won't back up factory settings
have the key turned to ON position but engine not running?
everything inside the truck turned off?
have anything aftermarket, like aftermarket stereo, subs, amps, nav, remote start, trailer brake/light setup, etc? if so, you need to to disconnect everything like that...
and make sure your battery is fully charged...
aftermarket stereo?
chevyguy0487
I unplugged my remote start the process seemed to start to work and saved my factory settings. turning the tuner install
it stopped midway said unpplug start over, did that then it said this needs to go back to factory setting click continue did that and at about 92% says it can't be written gives an error code of "PCM error write failed (-1)" and now my truck won't even start.
still sounds like there is some aftermarket electronics causing interference.
chevyguy0487
I JUST NOTICED YOU HAVE AFTERMARKET RADIO ON THAT LIST...WOULD THAT CAUSE THAT TYPE OF INTERFERENCE?
yes, just like I said..
chevyguy0487
yup that was the issue thanks for all your help.
